Xerox color 560 fault 127-211 - Office Equipment & Supplies
5790. How do I correct problem 09-560?
09-560
HVPS
High Voltage Power Supply I think.
Oct 02, 2015 | Xerox Office Equipment & Supplies
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
5790. How do I correct 09-560 fault?
That is a high voltage power supply error, start by cleaning the charge scorotron and corona wires and cleaning contacts. If error persists, replace the HVPS.
Feb 08, 2013 | Xerox Office Equipment & Supplies
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Dc12 error code 15-560
It's either the drum unit or the fuser from what i remember. Either way you do need a xerox technician to confirm and replace.
Nov 25, 2009 | Xerox DocuColor 12 Color Copier
Tektronix 540 error 32
Error 32 is most often caused by the cleaning blade clutch grease gumming up. Clean it completely with isopropyl alcohol and a lint free cloth and cotton buds. Re lubricate it with high temperature auto synthetic grease - make sure it has no mineral content.
Oct 07, 2009 | Tektronix Refurbished Phaser 560 Color...
jasbo
jasbo
