Question about Konica Minolta DiALTA Di200 Copier
My di3510 is indicating "error code c0500, how can I reset it?
    New Friend:
If u try resetting it to no avail and u try cleaning the thermistor or changing the heater lamp and yet could not get result. Lose the main board and read the fuse. If the fuse is faulty, copy the number from the board, buy the appropriate fuse and replace it. Good luck.
Posted on Jun 09, 2013
    Problem Solver:
  • 11 Answers
It cannot be reset if there is something wrong with your fusing unit or your power source in your place. try checking if the fusing unit is properly closed or try to look inside of it, maybe there is something blocking the thermostat. in resetting there is a small hole in the right side of the control panel, poke it with pin (just to make it click) this is during power on. then look at the screen on the left side there is a image of the machine there will be a dot appear right after you poke the switch. then quickly press the no. 3 button, then option panel will appear, if it has a code, try entering 8 zeroes or ones then enter. if you are already in, there is an option that says "TROUBLE RESET" you are freely to stare it. hehe. just select and wait, it will restart. if power shortage, buy AVR.
Posted on Apr 17, 2013
SOURCE: iMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Posted on Sep 20, 2011
  • 7 Answers
SOURCE: I am getting an error code C0500.
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Posted on Jul 13, 2009
checkitright
  • 1362 Answers
SOURCE: konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Posted on Oct 31, 2007
  • 17 Answers
SOURCE: Konica minolta Di3510 Tech Password
if three times you tried with wrong password at saem time you have to change ram
Posted on Oct 02, 2008
firecontrol7
  • 6788 Answers
SOURCE: error code c0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Reset c0500
Aug 08, 2016 | Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
C0500 error code
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
C-0500 code mean no power to the fuser inside mid cover front is a micro switch that provides the power to the fuser unit
Jan 11, 2014 | Konica Minolta Di3510 Copier
C0500 error code
Hi, Sir;
I believed this machine come with two heater lamp, change this two lamp position, and also thermistor have to be contact heat roller perfect, try it see what happen. good luck
0500 ERROR CODE
I am also facing this trouble, with Di3510. some time machine work for many copies fine. then suddenly the 0500 error code appear. I checked complete fuser unit... Both lamps are ok, Thermo switch is ok, i checked both thermistors and in my view they are ok (checked with multimeter while warming them). I first reset the code as mentioned in the service manual of this machine. the code can remove but it comes back after some time. I checked the Electricity voltage as this machine is 120v input. Voltage are ok. Then i ask my Electronic board expert to check the Power supply and he told me that the power supply is ok... just some dry sold he found. So until now i am not able to detect the trouble even though i arranged another fuser unit of the same machine and it also gave the same error code c0500. As i am a Technision of copiers. Please give any good suggestion if any one have. Thanks
Jan 09, 2014 | Konica Minolta DiALTA Di200 Copier
Minolta Di3510 cannot make copies error code Co500
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 30, 2012 | Minolta Di3510f Bizhub Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Oct 02, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
1,903 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
