Question about Microwave Ovens
Oven starts automatically when door is closed?
When i power the oven or close the door, the oven runs automatically. can i fix it myself?
  • Microwave Ovens Master
  • 9,047 Answers
It would help to know the full model number and whether the oven is actually cooking by itself when you close the door, or if just the fan, light, and/or turntable is running when you shut the door.
But either way, the first place the start is with the door switches and mounts. My help file on those is here.
If those are good, it may need circuit board repair.
Posted on Nov 28, 2012
SOURCE: Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Posted on Jun 20, 2007
  • 579 Answers
SOURCE: Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Posted on Dec 31, 2007
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
Skill Will
  • 53 Answers
SOURCE: Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Posted on Mar 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave keeps running....meaning when i close the microwave door it will automatically run.
The timer control has the problem so it need to be replace. But be sure you do not program the microwave to auto run when the door is close some microwave have that feature.
Hope my advice help you.
Apr 04, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
It runs when door is closed. there is no time countign down and it is not heating up. I can not cancel it either. it happened when i closed the door hard. and it just started running. any suggestions?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 07, 2010 | Samsung SMH9151 Microwave Oven
Power comes on but at the end of the cycle nothing is cooked
Please check the door safety interlock switches. These are the micro switches inside the case that tell the oven the door is closed. When you open the door while the oven is running, there is an arc on the contacts in the switches and they burn a little. After a while, the switches are no longer able to report the door is closed. When the door is not closed, the heat is not turned on. Forget what you know about the door being closed.
Check the switches.
Thanks for your question at FixYa.com
Feb 20, 2010 | Maytag MMV5000 Microwave Oven
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
Door latch on Emerson microwave oven
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
