Thank you bill chestnut for your reply, It's not a washing machine it's a hotpoint ultima dishwasher with what looks like one hot water feed pipe, can i connect cold feed to this, i have no ho
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You can hook it up like that but not sure how clean the dishes will get without hot water.
Posted on Nov 28, 2012
  • 196 Answers
SOURCE: I have been given a
You will need to use a Y-piece on the cold water valve, any hardware store will have them
  • 9k=
Then simply run 2 hoses to the machine from the 1 valve.
Posted on Mar 14, 2011
  • 1294 Answers
SOURCE: Gushing water - Hoover SPB11 washing machine
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
Posted on Dec 06, 2007
  • 13 Answers
SOURCE: Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Posted on Apr 11, 2009
  • 86 Answers
SOURCE: relocation of hotpoint aquarius 1000 washing machine
You don't need hot and cold connected to your machine you can use just cold, but you DO need a supply of some kind to both valves, or your machine will stop when it comes to the rinse cycle and it won't distribute fabric conditioner. Ask for a cold fill adaptor from any plumbers merchants. It looks like a plastic Y the single stem connects onto your cold supply tap and the two hoses from the machine connect onto the top of the Y. The machine will take longer to do a wash but it will work perfectly.
Posted on Jun 21, 2009
Treefrog15
  • 127 Answers
SOURCE: Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Posted on Feb 25, 2010
Does Hotpoint Ultima WF860 need both hot and cold pipes?
Only if you need to have both hot and cold water wash options.
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
HOTPOINT ULTIMA WD71..WHEN THE MACHINE IS SWITCHED ON TO A WASH PROGRAM IT WORKS FINE FILLING WITH HOT WATER THEN STARTS ITS CYCLE. WHEN THE MACHINE REACHES THE RINSE1 CYCLE IT STOPS WITH A E10 ERROR CODE....
Following is pre-typed, saves time - in your case just refer to 'cold' please ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
Can i run my ultima wma74 off the cold feed only?
Hi Naomi from retired Englishman in SW France,
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
John C
Jul 07, 2011 | Hotpoint WMA74 Front Load Washer
Just plumed in my hotpoint ultima it has done a
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
Mar 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WF860
image_bubbleanswer_04.gif I recently had the same problem with my Hotpoint Ultima WF860P and after some investigations, I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Andrew Algar - Brighton
Feb 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
