Question about Dryers
I'm buying a Whirlpool WED94HEXW Dryer. I need a left side punch out to vent the unit for my closet space. Can you tell me if the unit has a left side cut out? Does the Whirlpool internal vent
WED94HEXW Model number dryer.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is a diagram of that unit. It shows a left and a right side punch-out for venting. I hope this helps!
Posted on Nov 27, 2012
Testimonial: "Richard, Thanks very much. This diagram of the wed94hex was very helpful. I appreciate the quick response!"
  • Richard Roth
    Richard Roth Nov 28, 2012
    Thank you for using FixYa!
SOURCE: Vent Kenmore HE2 dryer from the Side, not the back
I'm in the same boat as you. Just had my dryer delivered today. Did you find a solution?
Posted on Jan 11, 2008
jsrock516
  • 5911 Answers
SOURCE: CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
Posted on Nov 11, 2008
  • 512 Answers
SOURCE: whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
erpaalai
  • 999 Answers
SOURCE: I have a venting question for a new Whirlpool 9550 steam dryer
The vent must remain the same diameter all the way out. Previously installed vents do not often line up well. To get the dryer closest to the wall the bottom method sounds like the best shot. I would build a frame from 2x6s so you can design it exactly to your purpose. A purchased pedestal will still have some limitations.
eric
Posted on Jul 02, 2009
  • 760 Answers
SOURCE: Install side vent for GE dryer
Unlike some other dryers that have knockouts on the side and allows the vent to come out the side I don't believe this one does. The air duct has the rear discharge outlet built right into it. Since it sounds like you don't have enough room to put a 90 degree elbow on the back of the machine, which would move the dryer out about 6 in, you might try one of those square duct dryer fittings. See link for example:
http://www.northlineexpress.com/itemdesc.asp?ic=5CO-89638&source=froogle&kw=5CO-89638. If you had to you could put this 90 degrees, and continue it out with retangular metal duct.
Posted on Jul 20, 2010
Where to install a dryer vent in the washer dryer closet
call keystone support they will tell you exactly where to and where not to drill
Jan 25, 2016 | Keystone 2013 Residence 405FL
Tip
Help - My Bedroom Doesn't Have a Closet for Hanging Clothes
Most bedrooms come with built in furniture closets for hanging clothes. But sometimes you come across apartments that don't have any facilities.
Here are some suggestions for what to do if you bedroom is lacking in a hanging space.
1. Check out some of the cheaper furniture stores. You might find that you can pick up a closet for a lot less money than you realized.
2. Buy a moveable fold-up closet. You can get ones made of canvas or plastic that can be folded up and packed away when you don't need them. They're not as stable as wooden closets but make a great temporary solution.
3. Use a shower rail or pole that you can attach to 2 sides of a wall. This can provide a secure hanging space without needing a big purchase.
on Dec 16, 2013 | Retail Supplies
How can i replace the back plate of my dryer with a flat one will not fit in space for hook up
Not likely such a thing. The funny shape probably has something to do with the air passages.
Mar 25, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Haier Commercial Cool air conditioner, model CPRD12XC7, 12,000 BTU that has 2 hoses off the back and is made to be vented thru a window. I want to install it in a closet with no windows. Can I...
Mark, the two hoses serve different functions (Fresh Air Intake & Hot Air Exhaust). Therefore, they would have to remain separate. Also, Haier does not recommend extending the length of the hoses, to accommodate a specific change in installation. And yes, they can be vented through a wall to the outside. But, you would need to use something similar to a clothes dryer vent termination on the outside. Most exterior dryer vent terminations have insect screening and a flap door that opens when air from the dryer pushes it open. This would be fine for the exhaust hose, but not the Air Intake Hose. I guess if you could carefully remove the flap door. it could be used on the Air Intake hose. Also, keep in mind that the unit requires a minimum of one foot air space clearance off the back of the unit, for proper air circulation around the unit. If clothes will be hanging in this closet, that may present an air circulation issue.
Hope this helped you, please let me know. Thanks.
May 26, 2011 | Haier Heating & Cooling
Dryer vent
some have a knock out plate on the right or left side. then you buy a conversion kit, which is an elbow and couple of pieces of pipe.
Jun 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
eric
Jul 02, 2009 | Whirlpool WED5800S Electric Dryer
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Convett my whirlpool gas dryer to vent from the side
Whirlpool makes a kit for this, however since you have a gas dryer, you will not be able to vent out the side the gas heater is on.
Take the front panel off and look for the gas valve it should be on the left side, if you need to vent out on the left side you will not be able too.
May 30, 2008 | Whirlpool Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
