Question about Kitchen Ranges
I get an EO F2 code on the control panel. When I press cancel it switches to bake at 350 degrrees and asks me to start. I press cancel and sometimes a 2nd off of 2nd on message comes on control panel
I disconnected the electric power, but it continued after I restored power.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 27, 2012
jsrock516
  • 5911 Answers
SOURCE: EO F2 code
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Posted on Nov 12, 2007
vest6
  • 196 Answers
SOURCE: F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Posted on Dec 30, 2007
  • 126 Answers
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: My Kenmore range model C970-628091 keeps beeping and flashing an F1 or F3 error code
Fridgetech is right. It's the temperature sensor. I had the same problem, but I was getting the F3 and F2 errors when attempting to preheat the oven.
A R Marshall said that he replaced the sensor but he still got the same F3 error. That happened to me too! It worked for a few weeks, then it began to malfunction again. It finally started showing preheated as soon as the oven was turned on, but never heated at all. One night at 3AM, the error code and beeper went off while we were sleeping! That happened on several occasions at various times of day, and it was necessary to kill the power to stop it. The power could then be restored and the error would stop.
Ours is a Hotpoint range (made by GE). It's my understanding that most ranges have the same or similar error codes.
The sensor was $85.00 at the parts store, but I got it on line for about $60.00 including shipping. The instructions said to strip the wires and then twist them together with wire nuts. But the new sensor had a plug that fit so I used it, and it worked for a short while.
As I looked through the problems and possible solutions, someone said look for burnt wires. So I opened it up and looked but there was nothing like that. Then I remembered the instructions that said to hard wire, so I examined the plug which seemed to have one short wire inside. I plugged it back in and tested with the same negative results. Now suspecting the plug I cut off both sides, stripped the wires and hard wired using two small wire nuts. It immediatly began working normally!
Something is wrong with the plug connector.
Try cutting out the plug and hard wiring before ordering a new part. But if you need a new part, eliminate the plug!
May God bless you and keep you safe!
Posted on Jan 22, 2009
  • 5 Answers
SOURCE: Kenmoore Electric Range - Error Code EO F2
That code means your oven is a piece of ****. Put out in front lawn on big garbage day. Get inside the oven and wait until the garbage men get there. Jump out and yell, "Surprise!". After you've had your fun go back inside, get your keys, and drive to the closest appliance store to get a new one.
Posted on Aug 15, 2009
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
New Wall Oven with error code F2 EO "Keypad Disconnected" How to fi?
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Oct 18, 2010 | KitchenAid KEHU309SSS Electric Double Oven
While using the oven, a code EO-F2- appeared and would no longe heat.
Sep 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
What does the error code F2 EO mean?
Sep 21, 2010 | Whirlpool Accubake RF362LXTT Electric...
Display reads EO -F2- stove top works, oven will not
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
ACCU BAKE codes come up e6 f2
You have the following error.
Cancel key drive line open
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
After a power down the range keeps coming up EO F2? I have reset using the OFF/clear button. Oven lights but trips off to EO F2
Hi. This code is an indication of a Shorted keypad (also called touch pad)
Follow the steps below to address this issue further.
1. Check keypad connector for firm connection (keypad connects to control board, via ribbon cable). Make sure the connection is sound, and not severed.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Dec 04, 2009 | Kenmore Kitchen Ranges
Blinking EO and F2
Jun 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
