Question about HP ScanJet 5300C Flatbed Scanner
Win XP PC does not recognise my SJ 5300C USB scanner
When connecting powered-up scanner to my Windows XP PC, there are no signs that it is being recognised by system (No additional usb devices shows up)
when i plug in power for scanner separately, the lamp lights up, then carriage moves a bit, and nothing more happens. lamp stays on.
are there any ideas what to do, besides simply throwing it out? (scanner is off warranty)
  • 1 more comment
  • Anonymous Jan 10, 2009
    thanks for helping, but:
    this scanner worked on other win xp systems without any additional drivers, using xp camera and scanning wizard...
  • hospi Jan 17, 2009
    Hp Scanjet 5300c worked fine on my XP PC after installing new Hp software. After being unpowered and disconnected from my PC for about 2-3 weeks, the computer does not "See" the scanner when reconnected and powered. I reinstalled software without any improvement. The scanner light only flashes after it attempts to move a bit. Same results with another USB cable and another XP computer. Another Hp scanner works okay on the initial Xp computer.
    None of the buttons work either.
  • Anonymous Mar 21, 2014
    Not being detected
  • 700 Answers
First thing i would do is go to the control panel and see if theres any thing in the camera and scanner profile. Then go to the manufactures site and see if theres an updated driver for the printer. if so download the new driver then see if it recconizes the scanner. if that still does not work then you may have to run it in a different compatability mode. good luck
Posted on Jan 10, 2009
5300c with windows 8
HP only has drivers for:
Microsoft Windows XP
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows 95
You may be in the market for a new scanner if simply plugging it in doesn't get it working.
ScanJet 5300c cse cxi PrecisionScan software driver
Mar 04, 2015 | HP ScanJet 5300C Flatbed Scanner
Is Vista Home Premium Computer 32 Bit compatible with an HP 5300C scanner?
Your Hp scanjet 5300c scanner is not compatible with win 7 hoe premium 32-bit.hp does not have software or driver downloads available in that operating system.
Jul 27, 2011 | HP ScanJet 5300C Flatbed Scanner
Using HP 5300C scanner with Windows ME for years.
Are you still on ME? Might be time to step up to XP or vista, nevertheless, try this.. works great on my XP pro and Vista with some tweaking, but straight forward with XP Pro. Good luck! Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Jan 05, 2010 | HP ScanJet 5300C Flatbed Scanner
I've been using my 5300C scanner with Windows XP for years. Now, all of a sudden, my computer can't find it. My scanner is connected. I tried re-installing the scanner software but my computer tells me...
Most likely your scanner was put offline by a microsoft update. Mine was knocked out of business by a hardware driver update downloaded from microsoft update.
Try to roll back the scanner driver (my computer, system, hardware select scanner, properties, rollback driver to prior version) or go to your system restore function and do a restore to a earlier date when you know the scanner was working and see if that fixes it.
Worked for me. Windows XP pro
Oct 14, 2009 | HP ScanJet 5300C Flatbed Scanner
My hp scanner 5300c scanner has been problematic when installing on two different computers, causing both computers to need repair. Anybody else have a similar experience?
Download and install the latest driver for your scanner. The 5300c Scanjet did not ship with drivers for XP or Vista. A download is required for XP compatibility. Vista or Windows 7 should recognize the scanner without requiring additional software. If the software you are installing is not compatible it can cause issues with the computer. If you are installing from CD please look at the CD to see if it lists your version of Windows.
XP Driver Download:
Sep 12, 2009 | HP ScanJet 5300C Flatbed Scanner
Scanner lamp its blinking
After disconnecting and later reconnecting the scanner no longer worked. The lamp started flashing 6 times with pause. The scanner was no longer recognised by the computer. I fixed it by disconnecting the usb and current plugs, and reconnecting the current plug while pushing the first en third buttons from the left on the front of the scanner.
Feb 12, 2009 | HP ScanJet 5300C Flatbed Scanner
Scanner 5300c
Did you install the software/driver? Did windows recognize your scanner in your hardware profile? Don't use the software from HP, It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Jan 19, 2009 | HP ScanJet 5300C Flatbed Scanner
ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Nov 24, 2008 | HP ScanJet 5300C Flatbed Scanner
UMAX Astra 1220P Scanner worcks not with ( or in) Windows XP Home Edition . I need a driver for umax astra 1220p ( work under xp o/s). Thanks for all help.
I believe that the HP 3200C is a very similar scanner, and the
HP parallel driver will work, try the following links:
I think you will find that the old UMAX scanner is extremely
slow over the parallel port, and the image quality is nowhere
nearly as good as modern USB-2 scanners.
USB-2 is orders of magnitude faster than the parallel port,
and a really good scanner costs around $60 these days.
You may want to try the Canon LiDE 80: It scans pictures
and film, it's good, it's fast, it's dirt cheap and I love it.
Jun 14, 2008 | Umax Astra 1220P Flatbed Scanner
Umas Astra 5600 connection problem
what computer operating system are you?
Chances are this is a very old DOS scanners for Win 95/8- if your machine is XP/Vista it is not likely to work
Mar 18, 2008 | Office Equipment & Supplies
HP ScanJet 5300C Flatbed Scanner Logo
181 people viewed this question
Ben Johnson
