Question about Kitchen Ranges
Top oven of Maytag Genisis 750 Gas range will not light
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
Demy
  • 20 Answers
SOURCE: Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
textonor
  • 130 Answers
SOURCE: GAS RANGE
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Posted on Jun 13, 2008
huuum
  • 750 Answers
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Posted on Oct 16, 2008
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
Electric ignition on a gas oven
The ignitor is probably weak. It glows but is not very bright. Mellow orannge color? Replace it.
READ HOW IT WORKS
Jun 08, 2009 | Kitchen Ranges
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No ignitors on gas range top
Pull out the bottom drawer and look for a cover over the spark ignition module. The ovens have glowbars and they have nothing to do with the top( different circuit).40a0b9a.jpg
Mar 11, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Maytag MGR575qdq gas oven
Replace thermostat in oven and this should fix ya!
(Please rate answer to help keep this site FREE!)
Thank You!
Dec 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Dec 17, 2008 | Maytag MGR5751AD Gas Kitchen Range
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
