Light for temperature not on but seems to be working ok
Light on freezer not lit. The light in the fridge come on ok Seems tobe working working ok
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not a projection TV issue where it is posted.
Posted on Dec 22, 2012
Fridge temperature has stopped working but freezer is still workijg but fridge light still on..help asap!!!
OK! The light on the fridge is activated by a switch on mounted somewhere the door hits to turn it off when the door is closed. How do you know the light is on if the door is closed. Check the switch and manually press it in. If the light doesn't go out the switch is bad and will have to be replaced.
The second issue of the Freezer working but the fridge part not working. The cooling coils are located behind the rear panel of the freezer. If the blower is blowing, you may have a chronic ice build up on the coils which limits air flow. The fridge is supplied its cold are through the vents at the back of the freezer along the bottom and cold air is blown into the fridge through these "Vents". Make sure nothing is obstructing them. Hope this helps.
Bill
Sep 27, 2016 | Refrigerators
Servis Fridge Freezer Model # M7973B-I/1 light flashing
Likely problem is the temperature setting control is failing.
Apr 04, 2012 | Refrigerators
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Repair failed light in fridge has it got a fuse,freezer light ok. light ok I thought the refrigerator light was out and I replaced. Still no light. The indicator of temperature was not lit either. Seems...
It may be the door/light switch located on the cabinet along one edge of the door. It can usually be removed by prying with a screwdriver and tested with an ohmmeter.
Dec 31, 2008 | Refrigerators
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
Fridge is warm, freezer works.
Smilar problem, but the model is GTH15BBMFLWW
Jul 16, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
