LG Flatron E2442 black screen
Screen is black and shows: D-Sub Out of Range 74.5 kHz/60Hz Cannot gain any access to the computer
  • 16 Answers
SOURCE: Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
SOURCE: monitor out of range
plz i have problem,,need help !! when i lanch vegas 2 game the monitor turn of and i see msg Out of range " freq,,",,,>> how to solve this problem plz
Posted on May 30, 2008
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
freetek
  • 5568 Answers
SOURCE: monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Posted on Dec 15, 2008
  • 11 Answers
SOURCE: My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Posted on Sep 01, 2009
I have a LG Flatron EW224 computer monitor. It was working great but one day the screen went blank and reads in the center of screen: D-Sub out of range 68.5Khz/85Hz. Does anyone know how to correct this...
This is usually due to your computer Video resolution being set to a setting out of the supported range of your monitor, Lowering the computer video resolution should solve this issue.
Oct 01, 2013 | LG Flatron 22" Super Led Ew224 1080p High...
Out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view http://www.techyv.com/questions/why-do-i-get-out-range-message-my-monitor for more information.
I hope this would be of some help.
Feb 05, 2012 | LG Flatron L1515S 15" LCD Monitor
I got on the screen following text : out of range 89.5 khz / 60 Hz.
Your PC video resolution is too high for this display to work. it should be set to the native resolution for best pictures: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
I have upto now been using my lg Flatron L1919S monitor as a tv with a separate tuner. Today i replaced it with an lcd tv and was going to use the monitor for my computer. However when i connected it up...
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 15, 2010 | LG Flatron L1919S LCD Monitor
Out of range 64.0 kHz / 60 Hz
Unfortunately if you cannot get the resolution down, you cannot use it.
Jun 18, 2017 | LG Flatron L1515S 15" LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
When I open game the monitor become black and show: Analogique shortcut 53.6 Khz/85 hz
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | LG Flatron L1752TX 17" LCD Monitor
Monitor problems
Dec 13, 2008 | LG Computers & Internet
Computers & Internet Logo
429 people viewed this question
David Payne
David Payne
