Question about HEWLETT-PACKARD HP Pavilion DV7-3169wm Laptop 6GB of Ram, 640GB Hard Drive, 2.5ghz, 17" (WA796UAABA) PC Notebook
Hinges replacement how change the hinges
  • HEWLETT-PACKARD Master
  • 32,281 Answers
Check out these WEB sites for instructions.
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
b>
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Posted on Nov 28, 2012
How to change hinge on dell laptop d810
You need to know which hinge you want to replace. Then you can find the hinge on Ebay cheaper than most manufactures, Also you can search on google search and find many videos with step by step disassembly and re assembly of the hinge.
Oct 10, 2016 | Dell Latitude D810 PC Notebook
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
REPLACE HINGE
This hinge is a cartridge and the bottom hinge has to be removed to replace it, then you just unscrew the cartridge and change it out, it's pretty simple.
Apr 21, 2014 | True TSSU-48-12 Refrigerator Commercial
Replace door hinge bushings on a Venture Van
a lot of times when the hinges are worn out, the easiest thing is to go to a salvage yard and get different ones,its sometimes faster to change them entirely than to take them apart..sometimes the actual hinge pins arent able to be serviced so this is a better option..good luck..
Jan 27, 2013 | 2000 Chevrolet Venture
Replace door hinge 2000 gmc sierra
How exactly are the hinges ruined? To change the door on Sierras you drop out the pivots the hinge swings on. If the hinge bodies are the damaged part it's going to cost you money. You will need to get a GOOD body work specialist to cut out the old hinges and re-weld new ones in. Get the specialist to check the body and frame in case the wind has bent something else.
Feb 01, 2018 | GMC Sierra 1500 Cars & Trucks
Change inspiron 1721 lid
Do you mean the LCD screen with the lid?
If so you undo the hinges and disconnect the video and power leads to the inverter.
This WEB site shows how to remove the screen/hinges.
Apr 28, 2012 | Dell Inspiron 1721 Notebook
A pin broke on the rear window hinge. do i need to replace the pin only or replace the whole hinge?
hi.
the only time i have known these hinge pins break is when they seize solid in the hinge due to corrosion.
even if you can get just the pin, the corrosion would normally still be in the hinge, and will eventually cause problems with the new pin.
i would just change the whole hinge, you know that there will be no further problems from that hinge.
Apr 10, 2011 | 2003 Ford Explorer
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
The door hinges on my 3210 have broken. can i get replacement hinges
hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
May 07, 2010 | HP Photosmart 3210 Printer
HEWLETT-PACKARD HP Pavilion DV7-3169wm Laptop 6GB of Ram, 640GB Hard Drive, 2.5ghz, 17" (WA796UAABA) PC Notebook Logo
102 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
