Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washing machine belt come off
The belt has come off both the pulley and the motor how can i get this back on ????
  • Hotpoint Master
  • 3,463 Answers
To refit belt, remove top cover and rear lower panel at bottom of washer.
Tilt the m/c towards you.,you may need assistance to hold m/c.
Put the belt round the motor pulley first, and then fit it on drum pulley, slowly turn the pulley feeding the belt round as you go, it will be very tight, so be careful not to trap fingers., just keep going until belt is on, there is no adjustment needed as belt is self tensioning.
The belt needs to sit in the middle of the pulley.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
  • 1 more comment
  • Barry Coates
    Barry Coates Jan 20, 2009
    I recently posted a solution to your question on how to replace belt on Hotpoint washer.
    I was wondering how you got on, as you did not leave any feed back or comment.
    I do like to have feedback, as this way,I know if I am providing the correct solution.
    Any comment would be welcome.
    Thanks.
  • paulrichard Jan 01, 2011
    I found that a good tip is to use cable ties to hold the belt on to the drum pulley, then pull the belt on by turning and then cutting the cable ties off.
    Another tip is to manually turn the drum in both directions with the machine on level floor so that the belt finds its own path on the drum pulley before turning on the electric and trying it out, e.g. on slow-spin cycle.
  • Houseywife Jan 23, 2011
    Just googled this problem on the off chance and found your solution - bingo! Washing machine working again. Thank you.
  1. After struggling for 2 hours tried what Barkencoa suggested and sorted the issue within 2 minutes ! Sound advice.
Posted on Mar 19, 2010
  • tetraman Apr 25, 2011
    KNVOSS ands barkencoa thanks for the advice with the Aquarious belt replacement. It was extremely helpful and saved me a lot of time. Getting the belt onto the motor spindle is a tight fit for sure and I was not looking forward to the job however it went easily and I thought that I could add something to the debate with the solution I arrived at. Firstly get the belt warm. It was a hot day when I did it so I simply kept in in the car for a while. If its cold put it in front of a fire for a bit. Next get the belt over the drum, take a piece of metal tube, I used an old bit of curtain rod but some 15mm copper pipe would also be ok. Pass the tube between the drum and the belt, engage the end of the tube onto the end of the motor spindle and press down the other end. Slip the belt along the tube until it is over the spindle. Hold the belt and pull the tube out. Position on the spindle and job done, no worries and no sweat.
  • 323 Answers
SOURCE: hotpoint washing machine belt come off
Either the motor has loosened enough from its mounting to shift to an angle instead of being straight in alignment to the pulley, or the pulley has . Whenever a belt pulley becomes misaligned or is shifted to a slightly off angle position, the belt will seek and climb up the edge that is out of alignment and make its way off.
The only other feasible explanation is that the motor or pulley has become loose enough in its mounting to slide one toward the other. A belt turning without enough tension to keep it tight and flat will, through centrifugal force, raise up enough out of its path to find the slightest misalignment and work toward that edge until it comes off.
Until this situation is corrected it will eventually find its way off again.
Posted on May 25, 2009
SOURCE: Hotpoint washing machine. Replaced drive belt
You most likely didn't tighten up the belt tensioner, this adjusts the tightness of the belt, so as it stretches, during use, this can be, adjusted out.
Posted on Apr 07, 2010
  • 245 Answers
SOURCE: Belt adjusting of wore out motor pulley
the motor does not come with the pulley you have to order it seperatly
Posted on May 24, 2009
barkencoa
  • 3463 Answers
SOURCE: how do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
Testimonial: "thank you,"
TheMobilian
  • 8220 Answers
SOURCE: washing machine wont spin
If the machine has a sudden power glitch you must reset it.
Here is the secret:
To Reset the Inverter Board: Machine off: Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
If you still have nothing or if that puppy is dead in the water, you have a open transorber. The part you would need is wh49X1004.
What does a transorber do? It is a line voltage filter which protects the delicate circuits in these crappy new fangled electronics. Just thought you would like to know. I have the service manual in a printable version if you want it. Let me know.
Posted on May 29, 2010
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Thanks
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Replace belt on Hotpoint Aquarius WM31 washing
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Apr 05, 2010 | Hotpoint Washing Machines
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
Yeah hello there , im trying fitt a belt two hotpoint washing machine wf100p , i havn't taken the back off putting the belt on the motor first the on two the drum wheel gradualy turning the wheel to put...
You are doing the right thing. Hook the belt onto the motor pulley, then onto the main pulley as far as it will go, use a few cable ties to hold it on the pulley and turn the drum anti clockwise, the cable ties will snap as the pulley turns. Hotpoint have made a tool for putting these belts on but you woudn't want to pay out just for one belt.Belt fitting Diagram link
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fix on a drive belt to a washing machine?
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
3,212 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
