Question about Hotpoint HSWP1000MWW 27" Top-Load Washer with 3.5 cu. ft. Capacity, 8 Wash Cycles, 3 Wash/Rinse Temperatures, 3 Water Levels and 630 RPM Spin Speed
Doesn't sound like it's working
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Could you please describe the problem you are having a little better please?
Posted on Nov 28, 2012
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
2001 dodge stratus Radio doesn't work bass & trebble lights blink always
you should let it recheck from a electrician, probably one of your wires loose or something burned on the first i could think
Feb 06, 2012 | Cars & Trucks
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
Sound in my toshiba laptop is very less , i have installed sound driver "context" . still sound is low.
This is your correct driver, please re-install it from here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2860981&rpn=PSK2LU&modelFilter=L655D-S5145&selCategory=2756709&selFamily=1073768663#
If this doesn't help you, you can try this:
2. Click on Properties and open the Enhancements tab. Beware, You might not have Enhancements tab, lust like me. Go to next suggestion.
3. Check the Loudness Equalization checkbox then press Apply then OK.
If this trick doesn't work for you nor you can't find the Enhancements tab on your Sound's Properties (just like me), then try this next trick. Use VLC Media Player When playing your favorite music or movie, try using VLC Player. VLC Player as a unique volume meter that goes up to 400% of your maximum pc volume.
May 11, 2011 | Toshiba Satellite L655D-S5145 Laptop
Heater doesn,t work. Controls on dash sometimes light up & sometimes doesn,t. All of my fuses are good. It seems to act up mostly in the morning. Sometimes if I turn my head lights on my gauges quit...
Morning Charlie,
If it were me, I would check the wires coming & going to & from engine. Maybe something is crossed. That's what it sounds like, anyways.
Oct 08, 2010 | 1996 Jeep Cherokee
Hotpoint HSWP1000MWW 27" Top-Load Washer with 3.5 cu. ft. Capacity, 8 Wash Cycles, 3 Wash/Rinse Temperatures, 3 Water Levels and 630 RPM Spin Speed Logo
88 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
