Urlmon.dll not found whith device manager
I'm running XP on my system and just recently I tried to access Device manager, for some reason though it can't find urlmon.dll
Any help or ideas of why that could be and any solutions would be greatly appreciated.
Thanks
  • mark684 Jan 14, 2009
    Unfortunatly neither of those worked, I still couldn't open device manager in safe mode.
    Also when I tried to click on the urlmon.zip i can only highlight it, so I went into zip to extract it but my comp can't find c:\windows>system32 folder
    Thanks for trying proton.
    GOt it all working, just had to alter the location slightly, thanks for ur help Proton!
  • 1,183 Answers
The URLMON.dll is a system file , that might have got corrupted . You can download the same from the link below
http://www.dll-files.com/dllindex/dll-files.shtml?urlmon
Save the file on the desktop and then extract the file to the following location
If the same doesnot fix the issue , check by restarting the system in safe mode. Restart your computer and before windows begins to load tap the f8 key multiple times , till you see the safe mode option on the screen . Login as the administartor and check if you are able to open device manager . If yes , then just create a new user account the problem would be resolved
thanks
Proton
Posted on Jan 10, 2009
The hyperlinks are not working in my emails and in some other websites but they do work in google.
If you are using Outlook to browse yor emails here is the way to fix the hyperlink problem:
Follow these steps:
  1. Click Start, click Run, type the following command in the Run dialog box, and then click OK: regsvr32 urlmon.dll
  2. Repeat step 1 for each of the following commands:
    regsvr32 mshtml.dll
    regsvr32 shdocvw.dll
    regsvr32 browseui.dll
    regsvr32 msjava.dll
Dec 05, 2010 | Microsoft Windows XP Home Edition for PC
No audio device installed i installed all
If you are using IE 7/8 you can try to run the program without loading any add-ons to see if one of them is causing the problems. To do this, click Start -> All Programs -> Accessories -> System Tools and then click Internet Explorer (No Add-ons).
(You can also load IE without add-ons by clicking START --> RUN and then typing iexplore.exe -extoff)
If those don't work try to re-register IEPROXY.DLL by clicking START --> RUN and typing regsvr32 IEPROXY.DLL and then clicking OK.
When IE dissapears does IExlorer.exe show in the task manager's list of running processes?
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reg in out
Nov 05, 2010 | Acer Aspire One PC Notebook
Laptop: Toshiba Satellite NB200.Problems when restart after upadated antivirus (kaspersky 2010) this message appear: STOP:c0000221 [bad Image Checksum] The image urlmon.dll is possibly corrupt.the...
Yes it may be possible, installing and updating antivirus may have figured our corruption in urlmon.dll deleted the file or did some changes due to which you are getting the critical error
You can try 2 things,
1. Restore earlier settings, which may uninstall your antivirus and you need to install again. But if this works recommend you to first scan the system with free standalone antivirus availalable and then install your version of antivirus. Try following link
http://go.trendmicro.com/housecall7/HousecallLauncher.exe
http://www.trendmicro.com/ftp/products/rootkitbuster/RootkitBuster_2.80.1077.zip
2. Repair the URLMON.DLL file
1.Insert your Windows XP CD in your CD-ROM drive and boot your computer from the CD.
2.When the Welcome to Setup screen appears, press R to open the Recovery Console.
3.When prompted for an administrator password, type the password and then press Enter. In case no administrator password was set, just press Enter.
4.At the Command Prompt, type the following command and press Enter
cd %systemroot%\system32
5.Next, type the following command to rename the urlmon.dll file and press Enter.
ren urlmon.dll urlmon.old.dll
6.Now, to restore the original urlmon.dll, type the following command and press Enter.
expand [CD drive letter]:\i386\urlmon.dll %systemroot%\system32 /Y
7.Next, type exit and press Enter.
8.Restart your computer.
3. Repair complete OS. You will need XP CD
Boot from CD and follow the instructions to repair the OS
May 20, 2010 | Computers & Internet
Error 2738 pls give me answer
The error indicates that the VBScript DLL is not properly registered on the os. You should be able to fix it running the command on the command promp
regsvr32 vbscript.dll
before that try to search the location of the file on the windows, run the command with the path of the location of the file
May 13, 2010 | Logitech QuickCam Communicate STX Webcam
Did system restore,then it wouldnt load uo firt said wininet.dll missing,i fixed that but now urmol.dllmissing,the usb not working or cd,says something loke rundal dave something not found,can you please...
I have read through your comments and it looks like your Operating System (OS) is corrupted.
You can use that XP installation CD Service Pack 1 to install a new copy of Windows XP, then later upgrade to service pack 2 or 3 depending on your choice.
How ever, the errors that have been developed in your OS could simply be fixed by upgrading your service pack, to service pack 3.
Follow this link to download service pack 3.
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
If it fails to install or if it fails ti fix the errors, you will have to make a new installation of Windows XP using the CD you have, then upgrade to Service pack 2 after the installation.
Follow this link to download service pack 2, which you will download and install after you have installed a new OS.
http://www.microsoft.com/downloads/details.aspx?familyid=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
Now, to install Windows XP, follow the steps below that i have provided.
How ever, i would advise you to back up all your data, on the desktop and in the My Documents folder to an external location like an empty CD,or flash drive or to a different partition, to prevent data loss.
After data backup, follow these steps to install Windows XP.
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
Thank you for using Fixya,
Kenneth
Feb 14, 2010 | Office Equipment & Supplies
I cant seem to open up my internet explorer
To resolve this problem in Internet Explorer, follow these steps:
  1. Quit all programs that are running.
  2. Click Start, and then click Run.
  3. Type regsvr32 urlmon.dll, and then click OK.
  4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.
If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below):
  • Shdocvw.dll
  • Actxprxy.dll
  • Oleaut32.dll
  • Mshtml.dll
  • Browseui.dll
  • Shell32.dll
Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
If the problem is still not resolved, verify that the following registry values are present and correct: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Jan 24, 2010 | Computers & Internet
MSVCR71.DLL NOT FOUND
If the error started appearing soon after you have installed a new application or device driver, then it is possible that the error is occurring due to problems in the installation. To fix the error in this case, uninstall the software you installed and reinstall it.
Many times, errors related to DLL files, such as Msvcr71.dll, occur due to malware infections. Download, install and run Malwarebytes.
Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition
Invalid syntx error
The cause of this issue
CAUSE loadTOCNode(1, 'cause'); This behavior may occur for one or more of the following reasons: • The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file: [HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]This Behavior May Occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0. • The following registry key is missing or damaged: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046} • One or more of the following files is missing, damaged, or improperly registered: • Urlmon.dll • Mshtml.dll • Actxprxy.dll • Oleaut32.dll • Shell32.dll • Shdocvw.dll
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem in Internet Explorer, follow these steps: 1. Quit all programs that are running. 2. Click Start, and then click Run. 3. Type regsvr32 urlmon.dll, and then click OK. 4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below): • Shdocvw.dll • Actxprxy.dll • Oleaut32.dll • Mshtml.dll • Browseui.dll • Shell32.dll Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
Value: IDispatch
Thanks
Riz
Mar 21, 2008 | Microsoft Windows XP Home Edition
Windows xp updates
Why don't you try using this website, Reimage.com - its mainly for power users and PC repair professionals.
Jan 26, 2008 | HP Officejet 4215 All-in-One Color Photo...
Yahoo chat
  1. The Web Page that you are trying to reach might be out of service. Try visiting different Web sites to see if this message still displays from other sites. If visiting other sites also cause the message, continue using these steps.
  2. If you are using IE 7, reset Internet Explorer 7 settings and try again. If the page display problems persist, continue.
  3. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 softpub.dll In Windows XP , click Start , and then Run enter the following into the open field: regsvr32 softpub.dll
  4. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 urlmon.dll In Windows XP, click Start , and then Run enter the following into the open field: regsvr32 urlmon.dll
  5. Restart the computer and then try browsing the Internet again. If the page display problems persist, continue.
  6. Open Internet Explorer and click Tools , and then Internet Options .
  7. Click the Programs tab, and then click Reset Web Settings .
Sep 23, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
