Question about Whirlpool Refrigerators
Whirlpool Fridge mod# et8wtkxkq0 - will not run.
Only the light will come on. I read in another forum to jumper the cold control thermostat. Tried that still no go. This unit sat for a few years not being used, when I plugged it in it ran for about 3-5 seconds and then quit.
  • D Evers Nov 27, 2012
    Fixed it by manually advancing the defrost timer.
  • D Evers Nov 29, 2012
    The defrost timer takes 30 minutes to advance during this time the compressor and fan will not run. The timer can be manually advanced by turning the cam with a screw driver located in a hole under and behind the Cold Control.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Pull the relay off the compressor and shake it. If it rattles it is bad and will need to be replaced. Be sure to unplug the unit first! Here is the part to order if it is bad.
Posted on Nov 27, 2012
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Light on in fridge but no compressor sound or clicks or fan
That dude is probably stuck in the defrost mode.
OK try this:
1. Unplug refrigerator
2. Turn Cold Control to “off (Compressor is off)
3. Plug in refrigerator
The defrost cycle has now been initiated. The DTT has a bypass/test point for diagnosis. To terminate defrost manually:
1. Unplug the refrigerator
2. Turn the cold control “on” (Compressor is on)
3. Plug in the refrigerator
The defrost cycle is terminated and refrigeration cycle resumes.
Replace the dang adaptive defrost if you cannot get any response.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 10, 2009
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Posted on Jul 09, 2009
MY WHIRLPOOL WB360ME DOES NOT COOL
several things to look at,. the thermistors in fridge and freezer, the cold control thermostat, the freon level, the air damper flow control knob. is it closed all the way? is the fan running?
Mar 21, 2015 | Whirlpool Refrigerators
I have a Maytag ref. the freezer is working but not the refrigerator. Mod # B1954MES00
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Aug 24, 2011 | Maytag Refrigerators
Our whirlpool fridge/freezer has stopped working today for no obvious reason. There is still power being supplied to the unit, as the light is still turning on once the door is opened, but it is no longer...
You will need to check the following parts:
  1. Compressor start relay
  2. Cold control thermostat
  3. Compressor
  1. With the fridge unplugged, and an Ohm-Meter in hand, remove the Compressor start relay after marking where each wire goes. The wires must be removed before testing the start relay.
  2. Use your ohm meter to test the white(overload) wire, with one meter probe on the terminal where the White wire went, and the other meter probe on the other terminals, 1 at a time, should read 0-1 ohm.
  3. For the brown relay, just put both meter probes in each hole, should read 0-1 ohm.
  1. Put the Compressor start relay back in place and hook the wires back up to it.
  2. Find the cold control thermostat, it is the Switch with a knob that controls the Temperature. Tap under the console and on the knob in your refrigerator section and see if it comes on.
  3. If the contacts inside that cold control thermostat go bad, then when you tap the console or knob the refrigerator comes back on again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | Whirlpool Refrigerators
My whirlpool refrigerator side will not cool
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Aug 03, 2010 | Whirlpool ED2FHSS Side by Side...
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Whirlpool fridge not blowing cold air but freezer
May 28, 2010 | Refrigerators
Too warm
First of all check to see if the compressor is running. If it's not running and you have no leakage of refrigerant. it is probably the start relay at fault, or the thermostat control is faulty. Check with a multimeter on ohms and check between common & start see what ohms it reads then check between common and run. see what that reads. then check between start and run, this should read what the other two read added together. if you have no readings then the compressor may be burnt out.
May 17, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
