Question about LG 37SL8000 37 in. HDTV-Ready LED TV
What is the price of a main board for lg37sl8000
MAIN BOARD HAS BLOWN WHAT IS THE PRICE FOR A NEW ONE
  • 8 Answers
SOURCE: replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Posted on Mar 13, 2009
dsacco86
  • 1077 Answers
Try this place, http://www.shopjimmy.com/catalogsearch/result/index/?q=42lc7d-ub&p=2
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Posted on Apr 17, 2009
  • 8457 Answers
SOURCE: After a lighting my set didnt work any more. I
Tries Shopjimmy.com,Partstore.com,or Ebay.com for parts.
Posted on Nov 23, 2009
budmrtn
  • 11361 Answers
SOURCE: I had an electronics guy tell me my white main
http://www.shopjimmy.com/catalogsearch/result/?q=LG+50PC3D+
Posted on Nov 25, 2009
budmrtn
  • 11361 Answers
SOURCE: TV went dead and called
You need to get exact number from the board: see here
http://www.shopjimmy.com/catalogsearch/result/?q=EBT57840508
Posted on Mar 05, 2011
Sony bravia 32" lcd tv won't power up
Crack open your power supply again and take a look to make sure all caps are intact and not blown or bulging. Next check the main board for any possible caps and resistors, not likely as there is an external ps but possible. If you don't see anything odd then there may be an issue with the controller chip in which case you could replace but it would probably work out to the same price as buyin a new tv
May 04, 2016 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can I configure a MA5616 with 256 ADSL2+ ports?
Yes, but the 64 ADSL2+ ports board price is high, also have requirement on main control board which may make your cost high, so suggests for small site purchase the Huawei DSLAM with 128 ADSL2+, if need more than that consider big MA5616 MA5600 or 2 units MA5616 using cascading.
http://www.thunder-link.com/HUAWEI-DSLAM_c126.html
Nov 27, 2015 | Computers & Internet
Samsing 50 inch Plasma- Main Board BN94-01658A Problem
Its either bit the bullet or buy a new set here--you are going to have to try that board to see if it cures it or not.
Where did you price the board?
The main board should have a number of large flatpack chips so that price may be ok, where did you get the price?
Dec 04, 2012 | Televison & Video
Tcpv10 main board
I've looked all over, that main board is on back order. However the typical price for the board is $120-$170. Personally, I would toss the TV on Craigslist as a parts set. If you get $40-$60 for the set as is, TAKE IT AND RUN !!! I would buy a new set and use the money you get from the sale of the old TV to pay for extended warranty.
Sep 06, 2012 | Panasonic TC-P50V10 TV
Dp50740 power led goes on and off
What you have is most likely a failed main board. These sets are known for this problem. There are several different variations of the main boards. Make sure you order one that matches yours. The main board part # will start with J4@#. The main board part # should be on a sticker either on the main board itself or on the coax input terminal casing. I hope you got the TV for a good price !!!
Sep 01, 2012 | Sanyo Televison & Video
What is the price of the main circuit?
Here is a link to the complete parts list for the OLEVIA 237T11 television:
http://www.shopjimmy.com/olevia-237-t11
And here is the direct link to the MAIN CIRCUIT BOARD for that model:
http://www.shopjimmy.com/olevia-sc0-p519201gmi4-main-board.htm
Unfortunately the above supplier appears to be currently out of stock for that particular part, although this should give you an approximate idea of what the standard asking price is for replacing that circuit board ($160 US).
Just keep searching the internet and on EBay for the exact circuit board PART NUMBER listed at the above site and you may find one somewhere else for less. The online inventory changes every day so you just have to keep checking back often.
Good luck.
Joe.
Nov 25, 2011 | Olevia 237T 37 in. LCD TV
WANT TO INSTALL MAIN BOARD ON SHARP LC52SE94U TV
Required board is available HERE and HERE
Click above links for price info.
Thanks.
Jun 23, 2010 | Televison & Video
The tv isn't getting any power. Is there a reset button or would it be worth trying to get it fixed?
Hello, This TV has no reset button, but it does have as far as I can tell a power supply board and a main board that price out at 69 and 77 dollars respectively. If you can of use a multimeter you can determine if the power supply is working and providing the main board with the voltages to energize the TV or if the power board has some visible damage(blown fuses, burnt resistors etc.). Those boards are available through some e stores like partstore and others.
Apr 21, 2010 | Polaroid TLX-01511C LCD TV
Ilo TV main board
there are a couple of things you can try out
  • replace the amall EEPROM. typically it has the part number format 24Cxx and is very cheep.
  • if that doesn't help, then check the price of the main logic IC on the board. if the price of the IC is comparable with the price of a new board, you may decide whether to put a new board or not,
but i think it's always better to fix the existing board rather than putting a cheap crappy chinese board. those chinese boards are unsafe and prone to failure.. and the picture quality is usually bad.
Nov 04, 2008 | iLO 3200 32 in. LCD Television
Main board price and part number
You can sent it to a compy called pts to have it rebuilt. much cheaper . whats wrong with the tv that you need a main board?
Apr 10, 2007 | Toshiba 57H81 57" Rear Projection...
LG 37SL8000 37 in. HDTV-Ready LED TV Logo
Computer Repairing
Computer Repairing
