Question about Nokia E61 Smartphone
Screen light doesn't turn off
While the phone doesn't doing anything the screen light doesn't turn off. Any ideas why?
  • Yoav Shilon
    Yoav Shilon Aug 08, 2007
    All the setting are as you wrote.
    The problem is that the screen light no always but from time doesn't turn off until the battery run out of power.
  • 46 Answers
Check your display settings. Settings, Phone, Display: Check that Light Timeout is set (I have mine setup for 20 seconds). This should do the trick. If you wish to conserve yet more battery power, set "sleep mode" to on and set a power saver timeout (mine is set to 1 minute). good luck.
Posted on Aug 08, 2007
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
Hi,my wildfire screen will not turn on,the home,back,menu buttons and led light up but the screen wont light up or do anything. have u any ideas ? thanks
Hi
if everything light up except the screen that means your screen is either loose(if you drop the phone) or you need to change lcd as it got damage.
Oct 02, 2011 | HTC Wildfire Cell Phone
Hello i had my phone laying on my bed and i must have fell a sleep and layed on it when i got up this moning the display screen was white with not picture i can call out and receive calls put i can not...
mcdevito75 here, I just imitated sleeping on a cell phne and found mine will turn off, try turning your cell phone off, (red button) and then turn it back on. If this doesn"t help call your cell phone carrier for their advise.
Sep 21, 2010 | Nokia 2680 Slide Cell Phone
Screen Light Sensor will not turn off. Phone is getting very hot!
IM NOT FAMILIAR TO THE PHONE BUT TRY TAKING THE BATTERY OUT AND MAYBE BLOW ON IT.. IF NOT I HAVE NO IDEA?
Feb 19, 2010 | Sony Cell Phones
Phone turns on, backlight comes on but screen wont work
frist wash the petrol and assid 2 check the display ok any more sent me mail sameer_mishra1@yahoo.com
Aug 24, 2009 | Cell Phones
My n70 only shows white screen!!
my cell phone did the same thing, there is no solution-most likly caused by humitity, just send it in for a new cell phone.
May 28, 2009 | Nokia N70 Cellular Phone
My blackjack's keys wont work
First off, how do you know it's the keys, rather than something else? More details are always helpful. An important question is, can you see or hear anything at all, by any means? If someone calls you, does the screen light up?
If you see incoming calls, but can't answer them because the keys don't do anything, then I'd ask if the phone might have the keyboard locked. You'll be able to tell because you'll see "Unlock" in the lower left of the screen when someone calls or you press the power button (top left edge, above the screen). If it's locked, pressing the "..." button to the left of the wheel will tell you how to unlock it (just the "*" button down by the "0" button on my Blackjack).
If you don't see anything when someone calls, you might want to figure out if the phone is working at all.
A couple of ideas (sorry if any of these seem obvious - it's bad form to miss simple solutions):
1. Is the phone powered on? You can turn it on by holding down the power button (top left edge, above the screen) for several seconds. If you make it to 10 without the phone coming on, then it might be the screen, the battery, or the phone itself.
2. Is the battery dead? Try plugging the phone in and then holding down the power button, as above. If it still won't work, try removing the battery, then plugging it in and doing the same thing over again. When you plug the charger in, you should see a Duracell-like image on the screen, even if the phone is turned off. If you still don't get any sounds or anything on the screen, it sounds like the phone has serious trouble - probably needs professional help.
3. If you hear sounds ("swooshing" on mine) when you turn it on or off and the keyboard lights up, but don't see anything on the screen, it sounds like the screen might be bad - probably needs professional help.
4. Finally, you could try connecting it to your computer with the sync cable. I haven't done that with mine, so you'll have to read the instructioins, but it might let you know that the phone is working internally, but having communications problems through the keyboard and/or screen. If that's the case, you can try fixing it yourself or get an estimate from a professional. Good luck!
Mar 29, 2009 | Samsung BlackJack Smartphone
Invalid battery
HI dear my motorola c261 set problem is dead set.so any prson have idea give me that perair the dead set problem...?my Email address is tahir0332@yahoo.com
Jun 05, 2008 | Motorola Mobility C261 Cellular Phone
Phone is dead
to turn off the phone just remove the battery and try.. after this if it doesn work out install the phone software again with the usb.
May 04, 2008 | Sony Ericsson W550i Cellular Phone
Nokia E61 Smartphone Logo
95 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
