Question about Health & Beauty
PP1 programmer will not work. All I see are dark bars when turned on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
What kind of chair, the programmers are updated often
Posted on Dec 04, 2012
Is there any way to slow down the speed control so my Dad doesn't drive like a madman ?
There is a hand held programmer that can be plugged into the front of the joystick at the charging port to adjust the speed, acceleration, and other parameters. The Penny and Giles PP1 programmer is available used on line or you can go into a local dealer who will adjust for a small or no fee.
Jan 12, 2016 | Pride Health & Beauty
Increase the speed
1) Press the speed button (two lightning bolts) up to 5-lights.
2) Get larger tires.
3) Have a dealer reprogram the controller - requires PGDT PP1 or Quantum programmer which is a dealer only item.
Jan 21, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 1121 can the joy stick be reset to factory default with out a programmer, and if not what programmer would i need or any idea on a dealer to reset it?
You would need a programmer to set the factory default on this model. The 1121 typically had a Penny and Giles VSI controller. You would need a PP1 programmer to adjust it. Call around to your local dealers and see who has one in their shop. It is a very popular and available programmer. If you bring the chair into them, they will probably program it for no charge while you are in the chair. I know that was my service philosophy for years. The shop will get your business down the road as a loyal customer. It should take less than 15 minutes to dial you in. Hope this helps.
Oct 04, 2012 | Pride Mobility Jazzy 1121 Electric...
I have a FWD hoveround and would like to bypass the 85% foward speed. Is there a way??
YES,
BUT NOT BY MUCH.
YOU NEED A PP1 PROGRAMMER BY PENNY AND GILES. PLIG INTO THE JOYSTICK (UNDER) TURN ON THE CHAIR AND PRESS THE UP ARROW UNTILL YOU GET TO SPEED ADJUST. PRESS THE UP ARROW SERVERAL TIMES UNTIL THE SPEED REACHES 90, THATS MAX. UNPLUG, SHUT OFF THE CHAIR AND TURN BACK ON. THE CHAIR WILL NOW REACH A HIGHER SPEED. IT WILL NOT GO TO 100. YOU MAY HAVE TO TAKE YOUR CHAIR TO A DME STORE TO BE PROGRAMMED.
GOOD LUCK
TIM
Apr 28, 2011 | Health & Beauty
My Jazzy 600 was plugged in & charging and I did not know this. I tried moving the scooter & it would not work. I tried on/off & fast slow until I finally found the plug in was the reason. Now...
I think I understand what you are describing based on some inadvertent button pushing on your part.
Sleep mode programming on the VSI controller by Penny and Giles Drive technology is the idle time of the power chair before it "goes to sleep". This computer menu is accessed using a hand held PP1 programmer that is plugged into the charging port of the joystick. Using this programmer one can scroll down to the sleep mode menu and set the time from I think 1 to 120 minutes ( I have not accessed this particular programming menu for quite some time).
If I put in 10 and save this number the chair will go into sleep mode after sitting and not being used for 10 minutes. The control may have dropped one of the settings due to a program glitch. I do not know of a way to reprogram this by pushing buttons on the control itself.
You should drive the chair into a local dealer who has a PP1 programmer and let them program it for you. This is a 2 minute deal and they should do this as a courtesy for you at no charge. If a technician comes out to your house they may charge you a minimum 1 hour labor charge.
While they have the programmer plugged in, have them check the fault log for any other problem areas. Hope this helps.
Feb 26, 2011 | Pride New Jazzy 600 Power Wheelchair by...
Pride jet 7.one motor goes faster than the other . is there any adjustment that can be made????
David yes but you will have to find a provider or technician that has a PP1 programmer to adjust the motor balance hope this helps
Jan 28, 2011 | Pride Mobility Products Pride Jet 7 Power...
How do you dial up the speed on the jazzy select 6
jrw if you are asking to increase the programmed speed of the chair then you need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased Hope this helps you
Oct 17, 2010 | Pride Jazzy Select 6 Indoor Power...
Hi, Can you help me? The assisted live where my Mother is, told her she can only go at a level 2 speed. Is it possible to limit the speed to a level 2 on her scooter as she wants to go faster, and they may...
Yep but you will have to find a provider or tech in your area that has a PP1 programmer. With the programmer he can set the top speed as low as you want and this will limit the speed even if mom has the speed pot turned all the way up. I had to do this for a lady who kept knocking all the knobs off the kitchen cabinets lo Good luck Hope this helps
Sep 05, 2010 | Pride Mobility Products GoChair
How do I change the presets on my mpv5 hoveround
You need a PP1 programmer available from P&G Drives here.
http://www.pgdt.com/products/index.html
Plug it into the joystick, power up the chair and it will take you to the various adjustments for max speed, min speed, turning speed etc.
There's some places on ebay that you can rent one for a week. Search for wheelchair programmer, and locate a pp1.
Nov 29, 2009 | Cane Health & Beauty
I need a used/remanufactured 50 Amp VSI Controller for a Pride Go Chair
Search ebay, you'll find them new and used, and make sure that the connection into the chair matches up with your chair...most will send you a picture of it, and also make sure that the controller is programmed for RWD (Rear Wheel Drive), or you will also need to get a PP1 programmer to reset it for your chair. If it came off of any RWD chair and the connections are the same, it will work on your GO-GO.
Oct 26, 2009 | Pride Go Chair Travel Power Chair
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
