Question about Cameras
Where is this located on 2001 Chevy S10. The blower speed only works on high and I checked the resistor on fire wall and it isn't that.
  • Cameras Master
  • 5,370 Answers
Its faulty resistor if the blower works on high mode.Because resistor is the part which controls the blower motor speed.
If the resistor is getting checked ok,then definitely the wiring from blower motor to blower motor resistor has to be checked.Or its very rarely faulty blower motor replay.==========To troubleshoot the issue i suggest check the following link below:-----Click the link below:----
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected.If its faulty it has to be replaced.
For blower motor testing and replacing,check the link below:----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Posted on Nov 27, 2012
Location of the resister for the heater fan 350 ford 2006
Its under dash panel.
HEATER BLOWER MOTOR
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
These will help.
Thanks.
Nov 28, 2012 | Ford F-350 Cars & Trucks
Heater fan only blows on high speed
most likely the resister. Not very expensive part and should be easy to change out if you know where its located ( usually under the dash) You can buy a repair manual for your model at any parts store, and be sure to ask the parts guy if he knows where its located. he might just be able to save you the cost of the manual. Good luck with it.
Nov 27, 2012 | 1998 Chevrolet Cavalier
1993 Chevy Astro Ext.--blower motor only works on high speed--
high speed blower oper. is seprate i would ck. the switch on the dash
Jun 10, 2012 | Dodge Grand Caravan Cars & Trucks
2001 chevy express fan motor doesnt work on high
That woul be a bad blower motor resistor or a bad blower motor resistor connection.Turn on the ignition switch and put the fan switch on high then pull on and wiggle the connector going to the resistor.These resistors get hot and usally melt the connector causing it to loose its contact with the prongs.The resistor is located on the passenger side mounted on the heat duct with to screws.
Jan 25, 2012 | 2001 Chevrolet Express
Trying to locate where the heater relay that hooks to the blower motor is located
It is mounted on the fire wall in a block of two or three relays depending on what equiptiment is standand in your vehicle.Its toword the left side near the ACand the blower motor units Like i said it depends on what you have some are intergrated into the motor . But if you have splice # S108 the goses to the relay and splits and goes to blower motor resistor unit then its the one on the far right hand side of the block. There all interchangable and work exactly the same. However the blower motor relay directs bat voltage to the blower motor olny at blower high speed setting.The blower motor resistors direct battery voltage at all other speed settings. S o in a nut shell if it works on high the relay is good and its the resistors or a connection issue. Try the connections first thats the most likely problem if you olny have high speed
Jan 21, 2011 | 1999 GMC Yukon
My blower fan only wrks on high. is there 2 separate fuses?
The blower fan only working on high is caused by only one thing, that is a defective blower motor speed control resistor, the resistor is located next to the blower motor in the air ducting, replace it and the problem is solved.
Dec 02, 2010 | Kia Sportage Cars & Trucks
2001 town and country front heater blower dose not work at all
the internal fuse box is located above drivers feet,and if you need to replace the blower motor resistor its located under the hood on passenger side behind the strut tower to the right a bit on the fire wall.no screws hold it in, has to be pulled out just snaps in.the only reason resistor would require changing is if your blower motor only has high speed .
Jan 17, 2010 | 2001 Chrysler Town & Country
1997 Chevy S10 pickup Fan switch for heater runs on high only.
replace the blower motor resistor located on the heater box were the blower motor is located the wiring to the blower may go to it. This is very easy to locate if you buy the part first.
Jan 06, 2010 | 1997 Chevrolet S-10 Pickup
Heat wont work 2001 lincoln town car cartia
Hello Callahan5922....this sounds like a stuck blower motor resistor. I assume the blower won't function in the a/c mode either? If you have a digital multimeter you can check this. I believe it's fuse #2....if the digital indicator goes up or down when you increase or decrease the fan speed thats good. Locate the blower motor resistor....you wil find it located on the fire wall behind the right valve cover hiding behind the heater hose, it's about the size of a cigarette pack. With the engine off, and key in on position, turn the A/C on High, and rap a tap tap tap on the resistor. You might be suprised when the blower motor takes off a runnin,
I hope this is the answer you need and i was able to help solve this for you. Good luck...
Apr 13, 2009 | 2001 Lincoln LS
Heater fan only works on high on my 2002 Avalanche
If your Chevy is equipped like most vehicles, the speed control is accomplished by a stepped or tapped resistor that has now failed. This may be located on the fire wall under the hood or near the blower assembly under the dash. When these resistors go 'open' inside, it will only affect the lower speeds since the fastest speed bypasses the resistor completely. Can't say how hard yours is to access but the part is pretty itself is cheap, guess that's why they fail so often.
Feb 19, 2009 | 2002 Chevrolet Avalanche
Cameras Logo
216 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
