Question about Maytag SAV3655A Top Load Washer
I have a Maytag washing machine and will not drain unless I reset dial to that setting. the model # sav3655aww
    Sergeant:
  • 198 Answers
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Posted on Nov 27, 2012
3 Suggested Answers
plnolte
  • 62 Answers
SOURCE: Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
Posted on May 13, 2009
  • 714 Answers
SOURCE: I have a maytag washing machine model PAV2300AWW
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 17, 2010
How to remove agitator on Maytag sav3655aww
Hello, All you have to do is remove the softner cap and there is a center bolt, Remove the bolt and lift up on the agitator thats all..Hope this helps. Please Rate My Answer.. Thanks
Jun 09, 2011 | Washing Machines
My Maytag washer was purchased in October 2003. Model No.: SAV3655AWW Problem: My washer is leaking from underneath. The hoses connected on the outside are very tight. Can this easily be repaired?
this coild be easy fix ... remove front cabinet and verify internal hoses or pump... if coming down bottom of tub the its tub seal and bearing and u arent gonna be happy on price very extensive repair and requires a specialty tools...very expensive usually around $300.00 parts and labor
Feb 03, 2011 | Maytag Washing Machines
Maytag Neptune Stackable washer/dryer will only wash one cycle at a time unless I manually move dial to next setting...also will not spin as of this morning. Model # MUE2000AYW thx
The timer motor is bad, you can order a new one at reliableparts.com , using your model number. For information on how to perform your repair please reply and i will be happy to help.
Thanks, Repairman45
Dec 19, 2010 | Maytag Washing Machines
Maytag sav3655aww will not drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 25, 2010 | Maytag Washing Machines
Maytag Atlantis washing machine
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Maytag SAV3655A Top Load Washer Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
