Question about Ovens
My kenmore elite stove model#790 the oven and broiler do not heat up but the fan runs
  • Anonymous Mar 16, 2014
    We have Kenmore Elite model c970-440932 stove/oven.the preheat feature does not reach temp.Recently set for 375 and did not reach temp after 55 minutes
    Sergeant:
  • 198 Answers
Since none of the burners or elements will heat, I recommend that you shut off the house circuit breakers for the range. Your symptoms point to a voltage supply problem. The range should have a double breaker (the two circuit breakers are probably connected together with a metal clip). The range clock control will light up if only one leg (L1) of that power supply is provided to the range. If the second leg of power (L2) is missing, then none of the burners or oven elements will heat. You could have a problem with the circuit breakers or the wiring on the terminal block at the back of the range. With the breakers shut off , I recommend that you pull the range out and check the wiring on that terminal block. Based on your description, you may find a loose connection or burnt wiring in that area. The image below shows wiring information for the terminal block and the junction box for the range. This information should help you check that issue. If you can find a wiring failure and restore a proper voltage supply to the range, then the stove top burners and oven elements should heat properly.If you find no problems with the wiring, then you could have a bad circuit breaker or a problem with the house voltage supply for the range. An electrician will normally need to diagnose and repair that type of failure. I hope that this information helps. If you need more assistance, reply with additional details. If you need parts, you can order them from the Sears PartsDirect website.If you get to a point where you need to have a service technician repair this failure, you can schedule service through this link: Sears Home Services .
Posted on Nov 27, 2012
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Top rack of cookies overcooked in a one year old Kenmore Elite 790 Electric built-in convection oven
It sounds as though the broiler element was on, causing the cookies to overcook. A bad oven temp setting switch would cause this. Set the oven to the same setting it was on for the cookie project, and check the element at the top of the oven. It should only heat when set to "broil".
murf427
Aug 03, 2012 | Stoves Ovens
I have a Kenmore Elite stove and the broiler element will not heat up, the element it's self is okay
number 1 unplug unit inspect the outlet which element plugs into you will see prongs that clip onto element make sure there not burnt thoes prongs are in ceremic caseings make sure they not broken or chiped causing a bad connection i hope that helps
Apr 08, 2010 | Kenmore Ovens
My 790.94322302 Kenmore Oven & Broiler stopped working
The odds of both elements going out would be unusual.Tried to look up any other parts but the only other thing is the control module without having a wireing diagram.There should be one on the back of the stove if you can trace wires back from elements.I know that if the oven is in clean mode it over rides the oven controls.But with the electronic controlls don't think that it is possible.
Feb 01, 2010 | Kenmore Ovens
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Oven and broiler will not heat top works fine kenmore 790
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 18, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
202 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
