Can i connect to a cold water feed, i do not have a hot feed
    Scholar:
  • 155 Answers
I am assuming you can select water temperature on your machine. Simply hook up your pipe to the cold water feed on the machine, and leave the hot water feed alone. Always select cold water on the machine before beginning a load. If it makes you feel better, cap off the hot water inlet on the washing machine.
Posted on Nov 27, 2012
  • 1294 Answers
SOURCE: Gushing water - Hoover SPB11 washing machine
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
Posted on Dec 06, 2007
ngfam1
  • 639 Answers
SOURCE: ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
barkencoa
  • 3463 Answers
SOURCE: WHIRLPOOL AWO/D 5726 - cold water feed only?
Most washers now made in the u/k, are cold fill only, but if the new washer is hot and cold fill, and you only have a cold supply, then it will tell you in the installation guide how to connect it to use it from cold only.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
barkencoa
  • 3463 Answers
SOURCE: hot point aquarius 1100
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
  • 6277 Answers
SOURCE: Does the wma76 hotpoint need a hot water feed? Is
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Posted on Jan 26, 2011
There is nothing to indicate that the machine heats the water. We thought by connecting the y piece and just using cold, it would only be cold water. .
Most new washing machines only require a cold water feed! You should only connect the cold water feed and leave the hot water feed disconnected and turned off at the valve.
Mar 19, 2016 | Washing Machines
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Hot or cold water
d/w need to be connected to the hot water or your dishes wont come clean
Nov 28, 2009 | Dishwashers
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hot & Cold Water connection - can I connect just to cold?
Yes it may take a little longer to process a cycle but yes all new machines are cold feed only now.
Jul 22, 2009 | Beko 24 in. D3731F Free-standing...
Is it OK to attach a hot water feed rather than cold water.
All dishwashers are suppossed to be connected to hot water. Who connected yours to cold water and why? Doesn't make any sense. Definately change it over to hot water feed.
May 14, 2009 | Asko D1716 Built-in Dishwasher
Is this hot or cold feed
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
Apr 17, 2009 | Dishwashers
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Dec 06, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
