Question about Electrolux EOG7330WN Gas Double Oven
Where is the reset button
Electric timer is off so grill and oven wont ignite
  • Electrolux Master
  • 3,463 Answers
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Posted on Jan 10, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Apr 07, 2010 | Neff U1421 Double circotherm Electric Oven
Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Mar 31, 2010 | Neff B1421 Electric Single Oven
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
I need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Feb 26, 2009 | Verona Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Dec 24, 2008 | Whirlpool RBS305PDS Electric Single Oven
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Electrolux EOG7330WN Gas Double Oven Logo
576 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
