Question about Proscan Televison & Video
How to program my proscan model plcdv3213a to dvr cable box
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
Posted on May 24, 2008
SOURCE: Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Posted on Sep 08, 2008
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
bshldn
  • 736 Answers
SOURCE: I keep gettting 'no CC
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
Posted on Dec 30, 2010
gopakumarg43
  • 74136 Answers
SOURCE: How do I program my
Hello
You can use code search functtion to find and synchronise the remote with that device you wants to use with. There are some codes prerecorded to the remote's memory. If anyone matches with the code of your device, it will synchronise. If it can't, understand that your remote control cannot be synchronised with that device by any way.
[1] Manually turn on the device you want to program the remote to control [2] Use the "Function" button located at the top of the Olevia remote control to select the type of device you want to program the remote to control ("TV," "STB," "DVD," "VCR," "Audio [3] Press and hold the "Enter" and "Function" buttons together. Release the buttons when the LED indicator light for the selected device flashes once [4] Use the number pad on the remote to enter one of the four-digit device codes [if you know the code] assigned to the device's brand. The LED light indicator light for the selected device should flash an orange light three times if the code was entered properly [5] Aim the Olevia remote control at the device you are programming it to control. Press the "Power" button designated for the selected device ("TV," "STB," "DVD," "VCR," "Audio," "A," "B" or "C"). The Power buttons are located at the very top of the remote control. If the device shuts off, the remote has been successfully programmed. If the device fails to shut off, repeat the above steps once more. An other way fro code search is:
Posted on Jun 05, 2011
I have a Proscan model PLCDV3213A. Cannot get the TV to go to Lock or Channel. Can get to Picture/Audio/Time/Set-Up. How do I fix this? Have unplugged TV & let it sit overnight. Not fixed.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 09, 2016 | Proscan Televison & Video
Diagram for fuse location in Proscan tv
Look for it at its main power supply regulator [SMPS] board. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Jul 28, 2016 | Proscan Recertified - PLCDV3213A 32" Black...
Proscan plcdv3213a wont turn on. When power button is pressed the proscan logo will appear briefly. Then nothing. Any help would be appreciated
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 23, 2014 | Televison & Video
I have a Proscan PLCDV3213A that I cannot figure how to work the DVD player
YOU HAVE TO GO TO YOUR MENU AND SWITCH COMPONENT TO DVD OPERATION .
Jan 11, 2013 | Televison & Video
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the...
Dec 30, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Televison & Video Logo
53 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
