Tv shuts off orange status lite comes on and a green blinking lite comes on instill the tv shuts all the way down!!???
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not possible to answer or suggest anything without brand and model number.
Posted on Dec 22, 2012
  • 179 Answers
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Posted on Nov 17, 2008
doin12volt
  • 233 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
turn the tv off, hold down device and menu buttons on the front for 5 seconds, you will get a code flashed out through the LED's.. the codes are as follows:
12   No error detected 22   Recovery from momentary Reset 32   Lamp Cover open 33   Air Filter Cover open 34   Lamp abnormality 35   Chassis Fan failure 36   Exhaust (Back Cover) or Lamp Ballast Fan failure 37   Engine (DMD or Lamp) Fan failure 38   Excess Lamp Temperature 39   Excess DMD Temperature 41   Short Detected 44   DVI Cable (between Chassis and Engine) disconnected
Posted on Dec 19, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
Slinteriors
  • 8617 Answers
SOURCE: Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Posted on Nov 26, 2009
Testimonial: "ty"
Mitsubishi WD-73638
lamp is gone needs replacement
Jul 08, 2013 | Televison & Video
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
When startin up it would show a message that air flow was blocked replaced the Thermal Sensor, now the timer lite blinks green then the lamp lite blinks yellow and the green light go out. I hav a new lamp...
After the TV has shut down, without pressing reset: press and hold both the Device (Input) and Menu buttons on the front panel until the green light starts flashing. It will flash a two digit code: 3-4, 3-8, 5-7, etc. You may have to let the TV shut down a couple of times (without pressing reset) before it will give the code.
Please post the code to help me determine the section of the TV that has failed and what it will take to repair it. It may be a good idea to repeat the test a few times to make sure the TV is giving the correct code.
Let me know.so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 21, 2011 | Mitsubishi WD-Y65 65" HDTV
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
Jan 16, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Right out of the box. doesnt work
Don't feel bad - these are cheap TV's and there are lots of problems with them. Just be glad it failed so soon that you can take it right back and get something more name brand this time.
Remember - always google the model number you are looking to buy (with either "repair" or "complaint" in the search) and you'll be less likely to buy an TV industry land mine.
Jan 24, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Temp lite blinks
Your ballace is most likely out. If not that your light engine is going out. You may be able to get a rebuilt one from www.vancebaldwin.com it will come with a new fan, and ballace.
Jan 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
