What's your problem?DELL INSPIRON 6400I TURN IT ON AND IT SAYS WINDOWS PRODUCT ACTIVATION SO I DO THAT TO REGISTER THEN SAYS CONFIG NETWORK SETT I PUT IT ON AUTO SAYS UNABLE TO ESTABLISH A CONNECT
I TURN IT ON AND IT SAYS WINDOWS PRODUCT ACTIVATION SO I DO THAT TO REGISTER THEN SAYS CONFIG NETWORK SETT I PUT IT ON AUTO SAYS UNABLE TO ESTABLISH A CONNECTION RETRY NOJOY THEN IT GOES BACK TO WIND PROD ACTIVATION I DONT KNOW WHAT TO DO TO IT
  • 2,878 Answers
Windows will slowly stop functioning if it was never activated till all you get is the mandatory activation screen. The problem you have besides the the activation is that your network card is not connecting to internet. You no longer can get into Windows to remedy the problem, because of the activation screen. Catch 22!
If this is true, you only option is to wipe and re-install Windows.
Posted on Nov 27, 2012
Nic61
  • 1073 Answers
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Posted on Dec 05, 2008
SOURCE: dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Posted on Jan 19, 2009
gnkanang
  • 63 Answers
SOURCE: Unable to establish a wireless internet connection
Hi
Does it pickup any wireless connections? Try updating the wireless drivers. the best way to fix this would be to test the card on a different laptop. If it works on a different laptop, your laptop will need to be weeped.
Posted on Mar 20, 2009
  • 73 Answers
SOURCE: Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
Posted on Apr 11, 2009
davidpsr
  • 222 Answers
SOURCE: wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Posted on Jun 11, 2009
Can't activate wireless
then go here on link ..
go down to network , look for wireless and download the driver
that is for your windows,,xp, vista ,.....
http://www.dell.com/support/drivers/us/en/19/product/inspiron-6400x
Jan 19, 2014 | Dell Inspiron 1300, 1501, 6400, 9200,...
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
Error 25004.config.xml not specified; A valid config.xml file must be authored when deploying '(null)'. i am installing microsoft office enterprise 2007 and i enounter this problem..how will i
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
Apr 25, 2012 | Microsoft Office Professional 2007 Full...
I want a legal product key for windows xp professional sp2 so I can register it with microsoft
Hello. If your computer has a windows XP Pro sticker on it you may be able to call Microsoft and validate your operating system if it is ligitamate, or buy an operating system disk on ebay for your brand of computer. Any Dell XP Pro disk will work with a Dell computer having a Dell XP Pro sticker, and so on for other brands, as long as your sticker has your computer brand on it. If you have a sticker without a brand name or no sticker at all you'll probably have to buy a retail disk.
These directions may be helpfull.
How to activate Windows XP by phone
loadTOCNode(2, 'summary'); To contact a Microsoft customer service representative to activate Windows by phone, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, I want to telephone a customer service representative to active Windows now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Follow the steps in the Activate Windows by phone dialog box, and then click Next.
    Note The number appears now and differs based on the location that you select.
  5. When activation is completed and you receive the following message, click OK. You have successfully activated your copy of Windows.
Jun 19, 2011 | Microsoft Windows XP Professional With...
Need to reinstall program that manages my network adapter---how do I go about it? I have a dell inspiron laptop-windows xp. Thanks in advance.
You don't really need one as you can use the windows wireless config utility.
If you have an internal network card then go to your manufacturers website and download the drivers from there.
Sep 04, 2010 | Dell Computers & Internet
#1 - just bought a 546 computer with windows 7. manual in package was for vista. how to get 7 manual? #2 how do I register my purchases?
To get the manual for windows 7, search windows 7 on microsoft.com
What do you mean by register? To activate and register windows or to register you dell computer?
Nov 07, 2009 | Dell Inspiron 546 MT Desktop Computer
Inspiron 700m \windows\system32\config\system missing or corrupt what am i supposed to do to fix this?
insert the windows disc and reinstall the program the might solve your problem and if it doesnt let me know.
May 20, 2009 | Dell Inspiron 700M Notebook
Windows xp is asking me to register my account
There should be a microsoft sticker on your CPU with the product key on it. you will need that set of numbers.if that does not work you will need to take the computer back to the manufacture/retailer and have them activate it for you.
Apr 16, 2009 | Dell Inspiron B130 Notebook
Adding Dell to Airport extreme
You wireless card can be controlled 2 ways, the card Wireless Utility (Dell Wireless or Intel Wireless Utility are the normal default ones) and the "Windows Zero Config" Windows wireless utility. You may need to go in to the Dell/Intel Wireless utility, and select "Let Windows Manage My Wireless" You should then get a popup saying wireless networks are available, click that balloon, select your network, and click connect. If secure, at that point you'll be prompted to type the passkey. If you are using an older Wireless card, it may only support WEP security. Vista and newer systems use a newer protocol, WPA.
May 09, 2008 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
