Question about Keurig B60 Coffee Maker
Keurig 60 reset
Can the computer part of the Keurig 60 be reset.
  • 1,511 Answers
Yes it can. Call for instruction : page 13 of manual
Posted on Feb 01, 2014
SOURCE: keurig b40
I dont think these machines are worth the money at all.
Posted on Aug 16, 2008
  • 2976 Answers
SOURCE: warning of lead in keurig coffeemaker
The solder joint in the tubing. Personally, I don't see a risk but the environmentalists see a risk in any lead at all. The plumbing in my house has ALL lead soldered joints. Now, plumbers are not allowed to use lead type solder. If the water just passes over the lead, there is absolutely minimal chance of problems. Keeping wine in a lead crystal decantor will also leech lead into the drink but, you don't hear all the hype about that. It's all about making the earth green. Toy wagons are being recalled because of lead in the paint. I don't know of ANY kids who ever ATE their wagon.
Posted on Jan 05, 2009
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
  • 3 Answers
SOURCE: Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Posted on Aug 05, 2010
  • 40 Answers
SOURCE: MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Posted on Oct 07, 2010
Get your keurig to prime
Google Keurig reset codes and find your model number. I had to reset mine and it worked fine since I found the codes. Y ou can also call Keurig and they can walk you through the reset.
Aug 10, 2014 | Keurig B66 3-Cup Coffee Maker
My keurig just stopped working. the water is fill but when i put a cup in and shut the lid it says "not ready".
It needs to be reset. Google. Keurig reset codes and find your model. Follow the sequence and it should work fine. If not call Keurig.
Jul 20, 2014 | Keurig B60 Coffee Maker
I want to set the off time for a B60 Keurig
Rest via the manual instructions. Take your time to do step by step procedures.
Oct 12, 2012 | Keurig B60 Coffee Maker
Keurig B 60 coffee maker doesn't brew
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 08, 2011 | Keurig B60 Coffee Maker
How to descale the keurig b 60?
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Dec 24, 2010 | Keurig B50 Coffee Maker
Keurig B-60 Single Service Coffee Maker Sticking Serving Size Buttons
you can put a windex and put it away whit a air pressuried can ( usaly used to removing dust on computer key board)it will probably remove the sticky source.
Jul 07, 2007 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
468 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
