Question about Zebra Eltron LP 2824 Thermal Printer
We have a zebra lp2824 and want to move it to another computer. when we go to install it we get a message that says continuing may harm our computer. what should i do continue installation or cancel it?
    Problem Solver:
  • 8 Answers
Usually the comuter asks that question for all downloads so dont worry
u can click continue =)
Posted on Nov 27, 2012
SOURCE: Slow printing to LP2824
This appears to be normal operation.
Posted on Nov 06, 2007
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
SOURCE: LP2824 Zebra printer software
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
Posted on Oct 02, 2008
  • 53 Answers
SOURCE: Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Posted on May 12, 2009
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Posted on Aug 05, 2009
I have to reinstall Zebra LP2824 to a new computer windows 7. I do not know what port to use to install it?
I believe this printer only has a serial (RS-232C) port. You may have to install an adapter card. Before you do that make sure a Windows 7 printer driver is available for that printer.
Jul 20, 2011 | Office Equipment & Supplies
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Bar code is not dark enough, can it be cleaned
Turn up the darkness setting. Here is a video on how to clean a printer, it isn't the same model but the procedure on the printhead is the same. At about 50 seconds into the video it shows the printhead which is basically the same on the LP2824. http://www.racoindustries.com/thermal-label-printer-cleaning.htm
Ben
Jun 25, 2009 | Zebra TLP 2824 Printer
Jan 13, 2009 | Zebra LP 2824 Printer
Oct 02, 2008 | Zebra Eltron LP 2824 Thermal Printer
Sep 16, 2008 | Zebra Eltron LP 2824 Thermal Printer
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
