Question about Yamaha RX-A820 7.2-Channel Receiver
I recently purchased a Yamaha RX-A280 after a lightning strike fried my old Stereo/Amp (Sony). I have a set of Bose 901 series IV with equalizer. Since the A820 has not tape loop I have read that some folks have used a separate stereo amp as a way of using the equalizer. I am wondering if there is a way to hookup a separate preamp to I could use the Bose system. Thanks!!!
    Sergeant:
  • 344 Answers
Exchange it for one that has tape in end out jacks on it,
Posted on Nov 27, 2012
  • Don McGrogan Nov 29, 2012
    Thank you Lissa, unfortunately exchanging the RX-A280 is not an option at this point.
5 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: want to use Yamaha rx-797 reciever with bose 901
I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
As to using 901's and 301's...
You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
Posted on Feb 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: i want to use my 901 speakers with the yamaha rx
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver2_bing.gif will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers2_bing.gif and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers2_bing.gif.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier2_bing.gif that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Jan 25, 2010
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
dunnbiker
  • 8546 Answers
SOURCE: How to connect bose 901
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input.
http://products.bose.com/pdf/customer_service/owners/og_901.pdf
Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Posted on Sep 05, 2011
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
I have a set of 901 IV with no equializer, I am
As far as I know, any equalizer will work. There is a guy on here that might know more about them, but I never had the Bose equalizer and I have Bose speakers for 35 years. The guy at the electronic store back then sold us a little equalizer at first, we graduated from that a long time ago, and now on the 3rd or 4th one. No problem, works great, sounds better than ever. Hope this helps.
May 11, 2010 | Bose 901 VI Main / Stereo Speaker
Want to use Yamaha rx-797 reciever with bose 901 and bose 301. Yamaha says tape monitor kills digital input signals. Also sya digital inputs are the optical jacks, RCA inputs are analog, but 797 does not...
Feb 15, 2010 | Yamaha RX-797 Receiver
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
How do i connect the bose 901 system to my yamaha rx-v2700
how about you connect your pre-amp out to eq-in and eq-out to aux ?
Mar 07, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Yamaha RX-A820 7.2-Channel Receiver Logo
212 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
