Question about Furniture Acquisitions Picard Armoire by Henredon
In moving my Henredon Armoire, the movers broke a front leg. Is it repairable?
How can I tell which Schwinn Recumbant bike I own? I've had it for over 10 years and it needs some repairs after the movers broke parts.
It is not necessarily important to know the model, as almost all of the parts are not unique to a particular model or even brand of bike. Knowing the model would not help most bike shops or especially online providers to find the right part. I would advise you to go to a local bike shop or bike co-op for assistance in determining what parts would be compatible. If the movers broke parts I would strongly suggest getting a repair estimate, including both parts and labor, to submit to the moving company - before you attempt any repairs. They have insurance to cover such issues.
Jul 30, 2016 | Schwinn Cycling
How to repair henredon upholstered chair
This is one of two things which I am guessing that this is a dowel and glue problem. Where it is separting causing the loose feel wilh have to be pulled apart, sanded, new dowel put in , glued and clamped. If these are screwed together than you will have to expose the heads of the screws, they will be covered with wood filler and then use a wood filler in that hole afer the screw is removed and put a screw back the same pllace once dried. The screw scenario means that all the use has caused the screw to loosen its hold.
Nov 12, 2012 | Henredon Fully Upholstered Side Chair...
I have a grandfather that i purchased in 1980. sold my home after 30 years and used a professional mover. they wrapped the wieghts and the clock was put in storage for 2 months.they refused to move me from...
Moving after 30 years takes a toll in unseen ways.
The clock is valuable for the memories, and it's loss can be symbolic of other losses. Nobody did this on purpose, and the young people hired to move stuff are never as careful as you would be. Years ago, I broke an antique bed we moved. The people said it was their grandmother's. I was inexperienced.
Five possible solutions:
1) Collect from the mover's insurance to pay for repairs?
2) Sue for damages to pay for repairs?
Spend $75-100 and file for damages in small claims court.
Except you don't know which mover caused the problem. Probably the first mover, but who knows?
Gather all the evidence you can, and assume the plaintiff will not show up in court.
Let's say you win the judgement.
Then you might have to hire a lawyer to try collecting the judgement.
People don't have to pay a judgement, unless you get a court order, which takes a lawyer.
3) Contact local clock repair and restoration company. The damage might be easily repaired once all is considered.
4) Do-it-yourself repair advice is abundant by searching 'grandfather clock repair'
5) Forgive and forget, and then buy another clock to replace the broken one.
Aug 20, 2011 | Hardware & Accessories
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
Washer vibrates alot
The following link may give you some pointers on what to check on your kenmore Elite to resolve the vibration problem:
http://www.fixya.com/support/r3633026-front_loader_excessive_vibration
This could be a matter of the legs becoming unlevel during the move, a shock absorber becoming damaged, or it could be the new location. These front loaders need a good firm and level foundation. Read through the link provided and let me know if you have any questions. I hope this helps you solve your problem.
Dec 18, 2009 | Kenmore Elite 45986 Front Load Washer
LG wm1832cw shaking bad in spin after move
manual,,lg.com...but befroe youdo that,,put the unit in spin ,,get a small wrench or the wrench that came with the installation pack..now when unit goes into high spin the fastest spin,,tighten the lock nuts on the legs one at a time dont turn the leg itself,,just the lock nut on the legs,,it might take two spin cycles but you will get it ..tighten all the way uop to the base,,,onthejob
Jan 09, 2009 | Washing Machines
Leveler Leg
this company has gone out of buss,? but the speaker company.com has either bought there exsisting stock or reproduced the same speakers i have the ST3 model that is now called TST3 or TST2 higher the # the more bass it can handle. awsome speakers and you cant beat the price. sorry if my typing stinks but i hope i helped someone out there if you bought sapphire when they where a hot item here's your answer lol pete n.j.
Nov 15, 2006 | Sapphire Technology ST2B Main / Stereo...
Furniture Acquisitions Picard Armoire by Henredon Logo
250 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
