Question about Lexmark X7675 Wireless All-in-One Printer
How can you change the burned out scanner bulb on a Lexmark X7656?
Bulb out
Are you saying that if you try to make a copy or scan, when opening the scanner bed cover, the bulb is not lit? If this is the case, then the scanner light "bulb" has gone defective now. Lexmark does not have a replacement for that part, you can try to have it repaired from 3rd party shops, otherwise, it's time to replace your printer.
Please try to contact Lexmark technical support center for other options.
Dec 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
My scanner no longer has the internal light that is needed to scan documents. Does the light burn out? And can it be replaced?
Yes, that scanner bulb can fail, as can the circuitry inside that lights it. Microtek's site lists a phone number you can call to check on replacement lamp availability, but you'd probably be better off buying a new scanner. It's not easy to change the lamp, and may turn out not to be the problem after all. Scanners are reasonably priced, and a new one would come with a warranty.
Nov 21, 2010 | Microtek SCANMAKER I900 Flatbed Scanner
Lexmark X1150 , scanner bulb very weak, use to be bright.
the scanner does use a bulb type ic reader but its not like a normal light i would say the printer has meet its end replace printer / scanner
Sep 25, 2010 | Lexmark X1150 All-In-One InkJet Printer
Where can I get an installation CD for my X6100
Go to the lexmark site and download the software. You can put it on your computer directly and once you have it you can burn it to disk if you want.
Nov 08, 2009 | Lexmark X6100 Flatbed Scanner
Fujitsu fi-4340C changing the bulb
Open up the ADF ****.
Remove Two Silver screws holding front
of top cover.
Remove screw from ADF release button.
Pull back of top cover to unclip.
This will enable you to see the rear lamp bay
and camera unit.
Lamp is situated under Camera unit.
ADF = Auto Doc Feeder.
Jun 09, 2009 | Fujitsu fi-5750C Flatbed Scanner
Need replacement lamp for visioneer 4400
Appears it is not replaceable:
Symptom:
The light has burned out and you want a replacement bulb.
Solution:
Visioneer does not provide internal part replacements.
Contact Support to troubleshoot issues where the light is no longer turning on, and if necessary, Technical Support will provide an RMA number for an exchange while the scanner is within the warranty period.
Need a Replacement Bulb because the Lamp Has Burned Out
Apr 04, 2009 | Visioneer 4400 Flatbed Scanner
Lexmark p-3150 scanner
Is the Scanner bulb goes on, during process, Is there any movement.
If not then the installation is not done properly, or either the Scanner driver are missing from the setup of All-in-One printer.
Let me know if you need further help.
Oct 01, 2008 | Lexmark P3150 All-In-One InkJet Printer
Copy Quality
open lid press copy is scanner bulb bright white if not bulb is burning out or has burnt out
Sep 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Lexmark X7675 Wireless All-in-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
