Question about Miele W1215
Miele W1512 Washing Machine
First I got the "Waterproof Fault" thought I solved it by turning off, tipping washer forward to release excess water, then turn back on, worked for quite some time. Now however the machine just doesnt work,the display is normal showing time, program & progress etc. but drum just does not move, makes a noise as if it is. If I turn off completely inc. at the mains and turn back on the display just shows where it was at before unplugging.
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 03, 2010
  • 6277 Answers
SOURCE: Hello, I have a meile 1714
Hi Aaron from retired Englishman in SW France (nothing on TV!).
Although I do not know your particular machine most good manufacturers' machines have a water sensor sensing water on the bottom panel. We have the same with our dishwasher.
Unfortunately it does indicate that there is a leak- either a split in a hose or a hose has come off, although both of those one would not expect so soon- 4 years?
If you are confident and reasonably competent -
REMOVE POWER
then remove the back- presuming that the back does come off as I would expect it to!!
You might be able to see what is wrong.
If you are really competent, and only if you are, you could put the power back on and see/hear where the water is coming from. That's what I would do before calling out a service guy/gal in case I could fix the problem myself. It's up to you Ash 1979!
Good luck,
John C
Posted on Feb 15, 2011
Display shows 'fault waterproof'. what is wrong?
I have been trouble shooting my own Miele issue and may have found your answer, which seems to be easily fixed. Apparently one can reset the water fault sensor by tipping the machine forward at 45 degrees. If water comes out the bottom pan, then you will have reset the sensor. You should check for leaks especially in the door gasket. However if it comes on again, you probably have a leak that you need to address.
Aug 31, 2015 | Miele W5877 Edition 111 Washing Machine,...
It is displaying the message and beeping at me waterproof fault
Put a towel down in front of machine. Tilt machine forward. Water should run off the sensor plate and fix this problem.
Jun 20, 2015 | Miele Novotronic Premier 500 Front Load...
My washing machine is a Miele and it wont start it is saying waterproof fault what can I do Please?
Have you tried to clean the filter recently ? If you have , water may have seeped into the machine, tip it forward and the water should drain out , if it does the same error you have something leaking inside the machine.
Mar 03, 2015 | Miele Washing Machines
Hello, I have a meile 1714 washing machine, it has worked fine since summer 2007 and has just developed a "Waterproof fault". I have tried draining the excess water via the drainage plug and...
REMOVE POWER
Good luck,
John C
Feb 15, 2011 | Miele Washing Machines
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
2. Unplug it
Jun 19, 2008 | Miele Washing Machines
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w930i washing machine
The machine thinks its flooded. Simply remove the drain cover filter and tilt the machine forward until water stops running out. Turn on machine and problem solved
Oct 02, 2007 | Washing Machines
Miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
May 07, 2006 | Miele Novotronic Premier 500 Front Load...
Miele W1215 Logo
151 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
