We have PTAC Model PTC153B50AM on our 4 Seasons Room and had to have the Control Board Repleaced since that had been done the unit is very loud is there something wrong?/what should we do? Kathy Nov. 27/2012
Pull the PTAC out and check the fan near the radiator coils. I have had a lot of problems with the fan getting out of balance and rubbing on the plastic shroud that funnels the air in. Over a prolonged period of time, it will also cause the fan to break down...
Posted on Nov 29, 2012
  • 659 Answers
SOURCE: Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Posted on Mar 17, 2009
  • 659 Answers
SOURCE: how to disable the energy saver of the amana ptac
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: I'm not getting heat from my unit..
the compressor is controled seperately from the fan, this is done with the thermostat, try turning the thermostat on then of or untill you hear the "click" sound from the thermostat. If the compressor is still not turning on this may be more than you can fix if your not familiar with electrical hvac troubleshoting... more than lilkely the thermostat may be bad, or your compressors starting components are failing...if the compressor is comming on when the unit is turned on you could have a freon leak causing no heat. hope this may help some there is just too much to write on the causes this will give you a start though!!
Posted on Jan 18, 2010
SOURCE: looking for manuel reset on heater amana ptac
I have a Amana PTAC Model PTH153A50AC with the DigiSmart upgrade kit (DSUK01B) which as of last night stoped generating heat. I tried the Diagnostic and got a "LF" displayed. But I find no reference to what LF means. HELP please. Also I looked but can't find a reset button either.
Signed
House without heat
Posted on Jan 31, 2010
  • 674 Answers
SOURCE: I have a Trane PTAC, MODEL 3 PTHD1201GBA. I just
Was the board exactly the same as the one you took off? Even if it was go back and check your wiring. That would be the first place to look since the board was all that was changed.
Posted on Jun 10, 2010
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Amana Ptac model PTC153B50AM, getting no heat
The heater relays on the circuit board are famous for going out in this model.. Can purchase circuit board for about $100 or individual relays for about $4. Have to solder them in.
Nov 13, 2013 | Amana PTC153B50AM Split System Air...
Model PTC153B50AM no longer heats
The heater relays (little black boxes marked "heater 1" and "heater 2" on the circuit board are known for going out. $100 will buy you a new circuit board, or you can order the relays from Digi-Key for $4 apiece if you are willing to solder them in yourself.
Nov 05, 2013 | Amana PTC153B50AM Split System Air...
I'm looking for a new power cord. Any Idea's where I might find part numbers and ordering information?
As long as you have the part number, if you have a D&L parts company listed
nearby, they can probably get it for you. They sell over the counter and even
UPS parts. They have a website as well. (This is where I get my PTAC
control boards). Hope this helps.
Mar 06, 2011 | Amana PTC153B50AM Split System Air...
I have an Amana PTAC that was just installed two weeks ago. I am starting hear a moderately loud warbling sound when it is in operation but not all the time. It's loud enough to wake me up in the next...
Is is the sound of water being thrown around? Some units actually sling the water from the drain pan back onto the coil. This improves efficiency. It's sort of a gurgling sound. Here's more helpful information is you need it:
<a href="http://www.ultimateptac.com/ptac-faqs/">PTAC FAQs</a>
Dec 19, 2010 | Heating & Cooling
Jan 17, 2010 | Amana PTC153B50AM Split System Air...
Mar 16, 2009 | Amana PTC153B50AM Split System Air...
8 flashes, bad IAT
Take the buttons off of your unit and remove the board cover by taking out the 2 screws on each side holding it in.  You will See on the right hand side of the board 4 post specifically , 2 for your indoor thermistor and 2 for your outdoor.  unplug your inddor  from the board ( make sure power is off)   and there should be a plate you can remove on the front of the unit on the right hand side of your evaporator coil , remove this and disconnect your thermistor from the coil (should snap right off )   pick up a new thermistor and just slide it right back in.
Aug 01, 2007 | Amana PTC123B35AE Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
