Question about Wega Mininova EPU Espresso Machine
I can not get espresso from the coffe nozzle - Wega Mininova EPU Espresso Machine
    President:
  • 1,618 Answers
Without the portafilter can you get just water from the grouphead. If yes check the grind on the grinder make it a little coarser. Think of your coffee grinds as sand and rocks: if you try to run water through rocks it will flow really fast, and if you run it through sand it will flow really slow.
Posted on Mar 26, 2009
One nozzle on the machine appears to be partly blocked. How can I get to it?
try running some hot water or try cleaning the nossle with a some niddle but stay safe don't over do it
Mar 06, 2016 | Coffee Makers & Espresso Machines
I Just bought a Saeco Intelia Focus espresso machine. I made coffe with 3 different coffe brands. Very good ones. And I became very disapointed when I try the results. Every time the espresso was way too...
Use less coffe , you are using too much , reduce the amout you are using . Presto . Also use homogenized milk , not skim , or fat free . Also use the water vapour to heat the cup before you make coffe , capuchino , caffe-latte, mocachino , espresso etc .
Oct 28, 2013 | Saeco Intelia Focus Automatic Espresso...
Steamer not working
Use a paperclip to clean out the end nozzle of the wand it might be blocked.
Dec 01, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My meile coffee machine cva620 is not froffing properly
check to see if your steam nozzle is clear unscrew tip and clean also run descaler thru to make sure steam tank is clear if still not ok steam tank thermostat may be faulty need to service machine hope this helps
Nov 05, 2009 | Coffee Makers & Espresso Machines
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Vienna not brewing
I wish I could post a solution, but this is exactly what happened to my machine after about a month of use. I don't see any clog nor a way to get to the moving parts that could create a clog. Unfortunate design.
Nov 28, 2008 | Saeco Vienna SuperAutomatica Coffee...
No water out of the filter spout
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Jan 11, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Wega Mininova EPU Espresso Machine Logo
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
