Question about Hotpoint Refrigerators
The motor by the freezer runs loud
The motor/condenser has started to make a loud humming noise. Everything is cooling properly and the ice machine works fine.
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
  • 219 Answers
SOURCE: Freezer Fan making humming noise until Turbo Cool is pushed - GE
yes need to replace
Posted on Mar 19, 2009
hiltonjug
  • 612 Answers
SOURCE: Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Posted on Nov 12, 2009
Testimonial: "I turned off the freezer side and it defrost for a few hours. Then I turned it back on and its working fine for 2 days now. "
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Refrigerator is making a very loud humming noise...yes, it is old, did turn off and restart, it was quieter for awhile but noise came back. Any suggestions?
A noisy chest freezer can be more than aggravating, it can also be a sign that something may be wrong with the appliance. With a little investigation, you will be able to find the cause for the noise so that you can determine how to rectify it.
Self-defrosting
If you chest freezer is a self-defrosting variety, you will find that it has a fan on one of the inside walls that enables this process to take place. Open the door and check whether this makes the sound worse; if this is the case, the problem is likely to lie with the fan. Ensure that it is not blocked by any food items or ice and is running properly. Clear away any items that are blocking it and tighten any loose fasteners. The motor that runs the fan can also cause a noise if it is old or defective and is struggling to continue running, if this is the case, the motor will need to be replaced.
Door Seal
Examine the door seal of the chest freezer to ensure that it is intact and has no defects. If there is a problem with the seal, it can prevent the door from closing properly which will force the freezer to work harder as it will also be cooling the air around the freezer. Replace the door seal and ensure that the door is able to close properly to see if this reduces the noise.
Element
The wire element that is either located on the rear or the base of your chest freezer. The element can often become noisy after getting covered in dust and debris. Rectify this by switching off the power supply before vacuuming the element. Carefully use a cloth to clean any other surrounding components that are affected by stubborn grime.
Ice Build Up
Where your chest freezer is unable to regulate itself, you may find that it can suffer a buildup of ice. When the ice become sufficiently thick, it will stop the freezer from being effective and will force the motor to work harder in order for it to keep working. Prevent this problem by defrosting your freezer on a regular basis or whenever it is required.
Condenser Fan
The condenser fan is likely to be located at the rear of the freezer and can become noisy if it is defective or covered in dirt. After switching off the power supply, use a cloth to clean the blades of the condenser fan if you find that the noise is coming from this component.
Compressor
The compressor is the black box that you will find on the base or rear of your freezer and is where the normal noise of the running the freezer comes from. The pipes and wires necessary for the freezer to work stem from this box and can become noisy if there is a problem, which is more likely with an older appliance. A defective compressor cannot be repaired so it will need to be replaced.
Take care in solving the problem.....
May 12, 2011 | Refrigerators
The freezer is making a humming noise from the motor, I think and everything is icing up.........i cant make it stop
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
Hi, my refrigerator is making a loud noise and it stops and starts about every 12 minutes. It is cooling fine. Can you help me? It is a side-by-side model that is only 4 years old. Thanks. This problem...
Good day,
Open the freezer door, and see if you can hear the fan motor, that is located behind the rear panel.
If it's the source of the noise, then you will have to remove the rear panel to access the fan motor.
If not, go to the back bottom of the machine, remove the back cover and see if the cooling fan motor that cools the condenser and compressor s working properly.
If it's alright, then it will probably be a problem with the compressor itself.
STOP !! The compressor has one year left on it's warranty.
Call your selling dealer for warranty service. This is an expensive repair and altering the machine can void the factory warranty.
Thank you for using FixYa
Jan 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not cooling, fan making noise and now humming
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Oct 27, 2009 | Admiral Refrigerators
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
111 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
