Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Iwant tomake setup for copy machine Xeroxworkcenter pe 16
Install the workcentre PE 16 in my laptop also
Posted on Jul 25, 2010
  • 77 Answers
Menu - set default - copy - ok.
Posted on Feb 17, 2009
Como puedo corregir falla en una worcentre pe 16 que se bloquea al sacar una copia o una impresion , para sacar otra copia o impresion hay que apagarla y volver a en cender
As I fix fault in a worcentre pe 16 crashes when removing a copy or a print, to get another copy or printing should be shut down and return in ing as I correct this fault tests can I perform
Jul 18, 2015 | Cars & Trucks
How do I get free mods for minecraft pe
Eat a magikarp then go to YouTube and search it up
Aug 16, 2014 | Android Apps
My whitemagic machine allows me to select a program and when i press the start button it shows PE error. This is happening since 2 days now.
This is a Pressure Sensor Error.
Remove the top of the washer. The pressure is usually located at the top. It will have a plastic tube about 5/16 in size. Remove the tube and blow down into it to try and clear any blockage. If that doesn't work replace the pressure switch.
Oct 27, 2012 | Whirlpool Washing Machines
XEROX PE 16 problem cru fuse error on display what is this
Remove copy cartridge. On left top of cartridge there is a glass fuse. replace it with proper rating. it is meant for cart existence
Jan 29, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
System crash
it depends what u want to restore? and what is the problem?
if its in the botting process (boot.ini, ntldr etc.. missing), then you can use any live cd and copy/edit them frome your disk, u can try barte pe or win-pe mini cd, **** its better to boot linux like puppy that loads in ram so u can insert ur recovery disk and copy needed files to your partitions.
May 07, 2010 | E-Machines eMachines Desktop PC
I need a user manual for yamata fy-100
The Yamata FY-100 is pretty much the same machine as the Brother PE-150 & PE-190d the only difference is the Plastic housing and the USB interface on the right side other than that there identical inside and the running setup is the same too. Hope this helps.
Apr 17, 2010 | Sewing Machines
Hi my name mohit manchanda. actually i wanna instal win xp in my [pen drive but after copying files 100% than sytem show fetal error
All that's needed is a bootable USB Flash drive with at least 256 MB of storage capacity and a Windows Setup CD. Using the program Bart PE Builder (Freeware), you can install Windows XP on the flash drive, along with other software as needed (and as available space permits).
Here is the link of Bart PE Builder
http://69.90.47.6/mybootdisks.com/mybootdisks_com/nu2/pebuilder3110a.exe
Here is the procedure
This will help you create your very first BartPE CD. It assumes that you are using Windows XP.
Make sure that your system has about 500MB of free disk space!
Download the latest PE Builder version (self-installing package) and install it.
Start PE Builder (pebuilder.exe). When you start PE Builder for the first time it will ask if you agree with the license agreement.
Now PE Builder will ask to search for windows installation files. If you don't have your windows XP setup/installation files on your system you must insert the original Microsoft Windows XP installation/setup CD at this point.
The files you have at c:\windows are not installation files. They are your already installed files!
Click "yes" to start searching. PE Builder will now search all fixed- and CD-Rom drives for Windows installation files. This will take some time. When more than one valid location is found, a dialog will appear where you can select which location you want to use.
At the main PE Builder dialog, select the "Burn to CD/DVD" option. When you are using an erasable medium, make sure that the "AutoErase RW" option is enabled. The "burn using" option should be set to "StarBurn". Select your CD writer device from the Device list.
Hit the "build" button. PE Builder will now ask you to create a BartPE directory, answer with "yes".
The license for your Microsoft Windows XP product is shown. Read it and agree to it to continue.
PE Builder will now start building BartPE. This will take a few minutes.
You will see a lot of files getting copied and/or decompressed, the ISO image build and the data recorded to your CD/DVD writer.
If the data verify was correct and there where no errors reported you can boot the CD/DVD!
After that set your PC BIOS to boot from USB,then restart.
That's it.
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
Can i install xp on pendrive ?
  1. Put the cd with xp on it in the cd rom
  2. plug your pen drive into your computer
  3. open "my computer"
  4. drag and drop the cd to the pen drive and it should copy the files to it.
Let me know how it goes.
Jan 05, 2009 | Microsoft Windows XP Professional
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
