Question about Wharfedale Televison & Video
Connecting up a home cinema kit
We have just bought a model DS-5957+AL-604 2.1 HDMI DVD Home Cinema Kit, and are having trouble conecting it up withe the leads supplied. We are trying to connect it to a Samsung T200. Any help would be much appreiciated. many thanks
  • christisumme Jan 10, 2009
    Thankyou for such a fast responce to this query, as i was just about to lose patientce with it!
    I will try what you suggest
    Thanks again
    Scholar:
  • 67 Answers
Heya,
The good news is that the monitor and the Home cinema can be connected but you need to get a cable. Bad news is the cable did not come with it.
The monitor has D-SUB, DVI-D
so you need a HDMI to DVI-D connector then you need another cable to route the audio to the system which you should have.
like ebay item
Item number: 220341264176Hope it helps
Posted on Jan 10, 2009
  • Mathew F
    Mathew F Jan 11, 2009
    Thankyou very much for the feedback :)
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How can i get a manual for the Wharfedale DS-5957 home cinema kit thanks
If google and manufacturer website are of no help then ask a search agency like manualfox.com - They find you every manual. The service is not for free, but often worthy (you only pay if they find what you are asking for).
Dec 12, 2009 | Wharfedale Audio Players & Recorders
Connecting ps3 to home cinema
For sound use the Digital Coax in, if the PS3 has digital out. Most HiFi home cinema systems have HDMI with all channels audio through HDMI. Check cinema settings to configure input for hdmi audio, also check PS3 audio output setting options to include all supported audio type by your receiver. It's not just a plug and play. Both systems need to gor through a user setup process to make sure they sync and play well with each other.
Jul 24, 2009 | Audio Players & Recorders
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Televison & Video Logo
144 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
