Question about Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Service menu settings plasma
Settings for r-cut, g-cut, b-cut, r-drv, g-drv, b-drv
    Top Expert:
  • Panasonic Master
  • 75,581 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Check this link too.
Posted on Nov 27, 2012
My tv wont stay on cuts on and off
The main board have some shorted component/s in the circuit. your set need a through checkup. Contact any experienced service technician.
Oct 06, 2012 | NEC 42XM5 42" Plasma Display 42 in. Plasma...
Pioneer plasma tv picture is cutting off heads
Issue may be adjustable in the Tech menu with your remote---you need to see if you can find the service manual (with schematics and information about getting into that menu and how to adjust).
Try to GOOGLE MODEL NUMBER WITH service manual or contact Pioneer.
Mar 21, 2012 | Pioneer Elite PRO-151FD 60 in. Plasma TV
Service menu codes for P42H401 plasma
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
50 inch plasma tv wont turn on what could the problem be please
MOST LIKELY THE POWER SUPPLY NEEDS TO BE REPLACED. I HAVE REPLACED OVER 6O POWER SUPPLIES THIS YEAR, VERY COMMON PROBLEM.
Oct 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
I am having trouble with the blue gun. It would
Be shure the guns are set properly follow below:
ADJUSTMENT PREPARATION:
  • Pre Heat Run should be finished.
  • Be sure Screen Color Temperature setting is in the COOL mode
  • Room Light should be minimal.
ADJUSTMENT PROCEDURE:
  1. Go to I2C ADJ. Mode. (With power Off, press the INPUT button on front panel and then press the POWER ON button then release. The Service Menu is displayed.)
  2. Set R DRV (COOL) to center data value (3F).
  3. Set G DRV (COOL) to center data value (3F).
  4. Set R, G, and B CUTOFF (COOL) data settings to [80].
  5. Adjust Screen VRs on Focus Pack fully counter clock wise.
  6. Choose SERVICE item [1] of I2C ADJ. Mode. Select CURSOR RIGHT and the Vertical will collapses.
  7. Adjust any Screen VR. Screen VR should be turned clockwise gradually until that particular color is barely visible.
  8. Repeat for the other two colors.
  9. Exit SERVICE MODE by pressing the CURSOR LEFT on remote.
  10. Exit SERVICE MENU by pressing the MENU key on remote.
Oct 12, 2009 | Hitachi 51F500 51" Rear Projection...
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
TV one side slight blurr
hello, here some help with this
hope this help below are adjustments
and values
How to enter into Service Mode
While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
seconds.
10.1.1. Key command
"1" button...Main items Selection in forward direction
"2" button...Main items Selection in reverse direction
"3" button...Sub items Selection in forward direction
"4" button...Sub items Selection in reverse direction
"VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
Value is shown as a hexadecimal number.
 ·Preset value differs depending on models.
 ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
Main item Sub item Sample Data Remark
ADJUST CONTRAST 000
COLOR 3F
TINT 03
SUB-BRT 800
WB-ADJ R-CUT 80
G-CUT 80
B-CUT 80
R-DRV E6
G-DRV F0
B-DRV FC
ALL-CUT 80
ALL-DRV FC
OPTION BOOT ROM Factory Preset
STBY-SET 00
Emergency OFF
CLK MODE 00
CLOCK 000
AGING RGBW
COUNT
ALL WHITE
ALL RED
ALL GREEN
ALL BLUE
ON/OFF
RAMP WHITE
RAMP RED
RAMP GREEN
RAMP BLUE
1% WINDOW
COLOR BAR
A-ZONE B-ZONE/4 TRIO
SCROLL
WHITE FLAME
RM-SET CODE A Fixed
SRV-TOOL - See next
10.1.3. How to exit
Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
good luck hope tis help.
Jan 18, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
HP 42" Plasma
I do not have a manual, but HP just replaced my Y Sustain board on my PL4260N (Model (ED429AA).
HP replaced it free because of a known problem with something they call "Plasma Mal-Discharge'.
The part number on the work order is 1032298-HS.
This did not fix my pixilation lines across the top.
I have been told that my Y-DRV is probably bad, but I need to pay for that replacement.
But, they did not verify that it is bad and did not guarantee this is what is wrong.
Jul 04, 2008 | HP PL4260N 42 in. Plasma HDTV
Panasonic TC-P50S1 50 in. Plasma LCD HDTV Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
