Question about Pioneer CDJ-200 CD Player
I plug power supply in and no lights or power come on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Either the power supply is bad or their is an internal issue with the cd player.
Posted on Nov 28, 2012
After about fifteen minuetsof playing it turns it self off it also feels warm to the touch
Solid green or solid orange light: Your power supply is working.
Flashing orange, solid red, or no light: Your power supply may need to be replaced. Try the following solutions:
  1. Try plugging your console's power supply into a different electrical outlet. Do not use a surge protector.
  2. If the power supply light is solid red or flashing orange, unplug the power supply and let it cool for 30 minutes. Then, plug the power supply back into the outlet.
There is no crack or damage done to it right?
Also try plugging it into the wall dirteclty no surge or power strip and let it lay flat
Nov 19, 2013 | Microsoft Cpa09-010a Ac Adapter Xbox360...
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
Ac adapter is red, what should i do?
This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if:
  • There is too much current.
  • The voltage is too high.
  • The temperature of the power supply is too high.
When any of these things happen, the light on the power turns red.
Solution 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
  1. Turn the console off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
  3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
  4. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on.
If the power supply light is still red, try the next solution.
Solution 2: Make sure that the power supply is plugged in loadTOCNode(2, 'whattotry'); Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution.
Solution 3: Plug the power supply into a different wall outlet loadTOCNode(2, 'whattotry'); To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution.
Solution 4: Order a replacement Xbox 360 power supply loadTOCNode(2, 'whattotry'); If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
To help the power supply work correctly, follow these guidelines:
  • Do not block any ventilation openings in the power supply.
  • Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply.
  • Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector.
hope this helps.
Apr 10, 2011 | Microsoft Xbox 360 Console
My powerbrick light is red all the time,does it mean i need a new one
it could and maybe not first diagnose the problem with what i oultine below. To see if anything fits into the category of your problem. Then try to hook up the power brick to another outlet in another room. If it does it there you can narrow down the cause of the problem.
THE CAUSE This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if: There is too much current. The voltage is too high. The temperature of the power supply is too high. When any of these things happen, the light on the power turns red. THINGS TO TRY Here are some things you can do to try and fix the problem.
Solution 1: Make sure that the power supply is cool The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red: Turn the console off. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on. If the power supply light is still red, try the next solution. Solution 2: Make sure that the power supply is plugged in Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution. Solution 3: Plug the power supply into a different wall outlet To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution. Solution 4: Order a replacement Xbox 360 power supply If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
MORE INFORMATION To help the power supply work correctly, follow these guidelines: Do not block any ventilation openings in the power supply. Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings. Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register. Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply. Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector
if you need an explanation or further assistance please let me know. I will be glad to help, Thanks -Midwest-tek
Aug 27, 2010 | Microsoft Xbox 360 Console
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
I have had the Hyvision MV220 monitor for 2 years now. I powered it off last night and it will not power back on this morning. There's a clear dot on the power supply and I'm not sure if it should be lit...
The light should be lit on the power supply when its plugged into the wall. Sounds to me like the power supply might be bad. Plug it into another working outlet and if it still doesn't light up then the power supply is bad.
If it lights up then you know the outlet is bad.
Dec 10, 2009 | MegaVision MV220 Monitor
Power supply light is red
This issue occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply will turn itself off if one of the following conditions is true:
Under these conditions, the light on the power supply turns red.
Step 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or that it has already overheated. If the power supply light is red, follow these steps:
  1. Make sure that your Xbox 360 console is turned off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall socket.
    For more information about how to disconnect the Xbox 360 power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect the Xbox 360 power supply
  3. Let the power supply cool for several hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall socket during this time.
  4. After the power supply has cooled for several hours, reconnect the Xbox 360 Power Supply to the console and to the wall socket.
If the power supply light is still red, go to step 2. Step 2: Make sure that the power supply is plugged in correctly loadTOCNode(2, 'whattotry'); If the power cord is plugged in to an extension cord, a surge protector, or a power strip, the current or voltage that flows through the power supply may not be correct. Make sure that the power supply is plugged directly into a working wall outlet.
Step 3: Plug the power supply into a different wall socket loadTOCNode(2, 'whattotry'); Try a different wall socket. Ideally, plug the power supply into a wall outlet that is elsewhere in the house.
Jul 16, 2009 | Microsoft Xbox 360 Console
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Pioneer CDJ-200 CD Player Logo
67 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
