Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire CPDS389CC2 OVEN ELEMENTS NOT WORKING
Elements not working, but control panel is operational
  • Official Brand Answer
  • 4,342 Answers
Hello Scott Plante - Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes and restart unit. If any proves to be ineffective and oven does not bake or broil contact a professional to move forward accurately. Range could possibly be experiencing an issue with a wiring failure, EOC and/or faulty elements which would need further diagnosing
Posted on Nov 30, 2012
  • 833 Answers
SOURCE: Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Posted on Nov 12, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
  • 530 Answers
SOURCE: Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
localwonder
  • 6784 Answers
SOURCE: oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Posted on Jun 23, 2009
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven not heating
In the oven, does the heating element and the broil element not work, or is it just one? You might just have a bad element, or a bad control board.
Jul 30, 2012 | Frigidaire Ovens
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Frigidaire GLEB30S8CSB- the broiler doesn't work, all other functions are normal. What do I need to look at? Many thanks...
Unplug the oven.
Remove the oven racks.
Remove the bake element.
Be careful and not let the wires fall back into the holes when you remove them from the element.
Use a volt/ohm meter set for ohms or continuity to check the broil element terminals.
No reading is a bad element. If no reading replace the element.
If the element is good the control panel will have to be opened to check for power from the electronic control to the element.
Re-attach the broil element.
Access the control module for testing.
At this point you will be working with live high voltage.
Turn the power back on.
If you are not comfortable with that please call a service technician.
If you want to do it,locate the broil out put wire and the neutral wire on the control. Set the control for broil,place your meter leads on broil and "N".
No reading is a bad control module.
A good voltage reading will be a bad wire to the broil element.
Mar 11, 2010 | Frigidaire GLEB30S8A Electric Single Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
128 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
