Question about Whirlpool RBD245PD Electric Double Oven
I NEED TO REPLACE THE ELEMENT IN THE WHIRLPOOL FCEM6 OVEN BUT DONT KNOW HOW TO FIND IT, I NEED A MANUAL CAN YOU HELP?
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: Need help replacing the Broil Element in our Whirlpool Dbl Oven GBD307
It is easy to replace.   Turn power off to the oven.    Remove the screws holding the element to the inside of the oven, Carefully pull the element out of the oven liner until you can unplug the wires from the element. Hook up your new element and ease it into place and re-install screws.
You can get the part from any whirpool servicer or you can order it from Sears.
Posted on Oct 13, 2007
SOURCE: whirlpool oven heating element
what are the meanings of gas marks,what is suitable for making pizza
Posted on Jan 22, 2009
bestdarngood
  • 3037 Answers
SOURCE: fitted new oven element still not working
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well, to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, then its bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the wiring and touch the probes from the meter to the contacts on the sensor. You can order a new sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
I need a user manual for an electric whirlpool oven FCEM6
All you have to do is go online to whirlpool website, support and manual downloads ..good luck ..
May 23, 2016 | Whirlpool Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
MY OVEN WILL NOT WORK, WAS WONDERING IF THEY HAVE A FUSE IN THE BACK OF THEM. NOT EVEN THE LIGHT WILL COME ON THE KNOB. IT HAS ON IT MODEL 6AKP603/WHAND THE TYPE IS FCEM6.
Check the Main Electrical Panel for your house or apartment. There will be a breaker or fuse in there for your Oven. If it's a new Electrical Panel it will have the Breakers, so reset them. If it's an older Electrical Panel it will have Fuses, replace them. Depending on the Building codes in your area it should be Two---30 amp fuses.
Jun 08, 2011 | Whirlpool Ovens
On my whirlpool oven FCEM6 the display says STOP and I can not get anything to work.
hi i have a whirlpool oven type fcem6 model akz151/1x i turned the oven on and it triped the eletric and the oven would not work so i got a new element and now just the grill works but not the oven help plz
Dec 28, 2010 | Ovens
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Oct 13, 2007 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBD245PD Electric Double Oven Logo
78 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
