Question about Philips 170S6FB/27 17" LCD Monitor
Philips 170s lcd - Philips 170S6FB/27 17" LCD Monitor
5 Suggested Answers
  • 27 Answers
SOURCE: Philips 170S LCD - OSD locked and unable to remove
It kind of sounds like one ore more of the buttons are stuck. Any chance something got spilt on them? Try pushing all the buttons repeatedly to see if any feel different or stuck.
Posted on Jul 01, 2009
  • 109 Answers
SOURCE: my philips lcd monitor in side dim please healps
It sounds like the backlight has gone out. Replace the monitor.
Posted on Feb 06, 2010
budmrtn
  • 11361 Answers
SOURCE: Philips LCD 170S Backlight problem.. only turns on
It can be DC filters caps with leaking/bulging tops, or they have high ESR, bad transistors or IC or transformers in the backlight inverter circuits, bad lamps assemblies. Please read below and look at the pictures of bad caps, failed monitors, and troubleshooting guides.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 08, 2010
SOURCE: Philips 170s LCD Backlight turns
After replacing 4 capacitors (all 25 V, 470uf) my Philips 170s turned on, but had the 1-2 second back light problem. I de-soldered and re-soldered all three (2 inverter and main power) transformer-back light works perfect now! I'm glad that did it-nothing like fixing one problem (no power) to find another!
Posted on Apr 07, 2011
Attention MONITOR CONTROLS LOCKED
You need to press and hold the "OK" button for 10 seconds, This will clear the control lock..
Jan 09, 2015 | Philips 170s Hns7170t 170s7fb 17" Lcd...
Philips 170s menu keeps on popping up
Sounds like a bad controller board. Board-level repair on a monitor controller board is quite difficult and bound to fail, for a number of reasons. You can look at the part number on the controller and try to locate a replacement online. Otherwise, the switch for the menu might be bad.
Mar 30, 2013 | Philips 170S7FS 17" LCD Monitor
Hello, my monitor (philips 170S) is going in "AGING . . ." when i turn ofg the pc..when its open the monitor keeps switching off and on constantly..none of the front panel buttons works while...
Open the monitor and chek with multimeter all buttons on the small PCB. (Front pannel buttons). On my Philips 170S the seccond button from left to right was defekt. Change the button and enjoy.
Jan 02, 2011 | Computers & Internet
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
Oct 08, 2010 | Philips 170S5FB 17" LCD Monitor
My philips lcd monitor in side dim please healps model philips 170s
Feb 06, 2010 | Philips 170S4FB 17" LCD Monitor
Philips 170S LCD - OSD locked and unable to remove display from screen, unable to adjust. Locked on Brightness setting which continually drops to 0. Any thoughts on how to fix?
Jul 01, 2009 | Philips 170S7FS 17" LCD Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
My monitor is upside down
my phillips monitor 170s has the brightness screen and the OSD controls locked/unlock how do I fix this
Jun 03, 2008 | Philips 170S4FG 17" LCD Monitor
Philips 170S6FB/27 17" LCD Monitor Logo
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
