Question about Fujitsu Stylistic ST5010 Tablet PC
My screen keeps going dark
If i move the tablet the screen goes black
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Sep 10, 2017 | Tablets & eReaders
Screen too dark
go into settings and look for personalisation the change your background if that dosent work its probably on night mode or you have it on auto set
Aug 31, 2016 | Acer ICONIA B1-710-83171G00nw 8 GB Tablet...
Why did this tablet stop working the day after my son was on?
Try this first Diana
How to solve the Tablet PC Keep Moving Forward problem
and there are also Video fixes..https://www.google.ca/search?q=+Tablet+PC+Keep+Moving+Forward&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=p5GAVtrbKqai8we67JyAAw#q=Tablet+PC+Keep+Moving+Forward&tbm=vid
Dec 28, 2015 | Tablets & eReaders
Tablet reset
Hi ihave kimo tablete but not run & start but reset By power&vol+ key but not reset please help me for install os .... my email h_flightsazan@yahoo.com
or
flightsazan@gamil.com
my site:
www.airship.blogfa.com
Thanks
Hassan
Jan 05, 2014 | Iview 754TPC with WiFI 7" Dual Camera,...
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
Mar 01, 2011 | Amazon Kindle Wireless Reading Device
Fujitsu Stylistic ST5010 Tablet PC Logo
29 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
