Why is my air pressure low in front but high in back on my 05 town and country
depends on how often you check tire pressures. you could over time be loosing air by it leaking out around the tire bead, or the tires hitting a curb or pot hole that can cause air to leak, a dirty rim may need to be cleaned or someone is keeping the pressures the same that is noted on the decal on the drivers door jam. I trust you have used a good tire gage and not just looking at the tires, as there is more weight on the front tires than the rear and the front will look like they are lower in pressure.
