Question about Zeiss Gdx/vcc Rnfl Scanning Laser Polarimetry Oct Tomographer Optometry
Screen is black
Power is on & machine warms up... can faintly see startup screen for a few moments and then the screen is so dark that you cannot view menu options. Blue selection buttons around the screen are lit and you can hear it selecting an option when you press a button, however, you cannot see which options you are selecting because the screen is black. Is there a contrast setting knob (like on a computer monitor)? or does it sound like the main fuse needs to be changed?
    Master:
  • 467 Answers
It sounds like the backlight of the LCD display is out. The Image is still being displayed there is just no light to illuminate the image. Try shining a flashlight on it (Put the light right against the screen) and see if you can see what's on the screen. The display is fairly easy to install but I do not know where you can purchase one directly.
Posted on Jun 26, 2017
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Black screen on Elite 8460p
Return the laptop, HP has a history with motherboard issues.
Apr 03, 2012 | HEWLETT-PACKARD Elitebook 8460P
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Left side of screen is dark
When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
Feb 14, 2011 | Philips Televison & Video
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
Dark or black screen when I open my notebook
Try resetting your NVRAM. Shut down your macbook. Press the startup button and then press Commmand-P-R keys simultaneously untill you hear two beeps. Then release the keys and allow the computer to start up.
If this does not cure the problem you may have a failing inverter board. Easily replace but not for the faint of heart.
Aug 17, 2009 | Apple MacBook Mac Notebook
Polaroid LCD on Digital Picture frame goes black during power-on
likely the old one had a bad inverter or a back light problem.
Jul 12, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Display won't stay visible
If you can see the moving image faintly then it sounds like a problem with the backlight on the screen. Backlights can fail, but usually a cause is an impact of some kind.
Dec 26, 2006 | Sony VAIO PCV-W20 PC Desktop
Zeiss Gdx/vcc Rnfl Scanning Laser Polarimetry Oct Tomographer Optometry Logo
1,911 people viewed this question
Top Zeiss Science & Laboratory Experts
Marcelo Ribeiro
Level 1 Expert
 Brian Main
Brian Main
S J Parkin
S J Parkin
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
