Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I have a dyson dc14 all floors vac it is making a very loud noise when i put it on carpet. whats the problem and how can i fix it?
  • Dyson Master
  • 18,424 Answers
Sounds like the clutch is the problem ,try this unplug the vac then lower the handle to the floor and back up again about four times it should adjust the clutch
Posted on Nov 27, 2012
SOURCE: Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Posted on Jul 10, 2009
b0sslady2001
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Posted on Aug 07, 2009
tvservice306
  • 458 Answers
SOURCE: Dyson DC14 Loud shrill whistle noise
Check and cleaning Brushbar Assy and Violet Cyclone Assy or replaced Brushbar Assy and Clutch Assy
Posted on Nov 04, 2009
Vac Belts
  • 701 Answers
SOURCE: My dyson DC17 makes a loud noise when i tip the
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Posted on Nov 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have a Dyson DC14
This sounds like your roller brush has stopped spinning for some reason. Turn the machine upside down when set to carpeting, and make sure the handle of the vacuum is down, as if you were in the vacuum posistion, and not up like the handle is when you're storing it.
Is your brush roller spinning? If it's not, there are two kinds of agitator brushes on the Dyson DC14, each has it's own troubleshooting.
If your beater brush is perfectly rounded in shape, then you have the newer style Dyson DC14 that doesn't use a clutch mechanism. Either belt has broken, or falled off, and is causing the brush not spin. Here's instructions with a pictorial on how to fix this problem;
Step 1. Unplug the vacuum cleaner.
  • Lay the machine flat on the floor and turn it over so that the base can be viewed.
  • Use a coin to turn the three soleplate fasteners and remove the soleplate as shown.
  • Check the brushbar for blockages and ensure the brushbar is rotating freely by hand.
  • If a blockage is present, carefully use a pair of scissors to cut away any hair and fibres from the brushbar ensuring you do not cut any of the bristles on the brushbar.
If the roller brush still doesn't spin after checking and removing any obstructions, then you need to replace the belt (or clutch if you have the early models). Here's a video that explains how to replace the clutch mechanism on Dyson vacuums;
If this failed to fix your problem, or if you have any other problems or questions, please feel free to just reply using the comment box below, I'm always happy to answer anyones questions or concerns. I hope this helped you. Please do be sure to rate my repair, or leave feedback for me if this helped. This is greatly appreciated by the Fixya community.
Chris Jones
GoVacuum.com
Posted on Jan 06, 2011
Loud noise with belt protection system On
I'm sorry to hear you're having difficulties with your DC14. The knob you're describing is the brush control, which turns the brushbar on when set to 'Carpets', and off when set to 'Hard floors'. The machine may not pick up hair from carpets if you have it set to 'Hard Floors'.
The brush control system is also designed to make a ratcheting sound to warn you if something is jamming the brushbar. The easiest way to check for and remove any obstructions is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=668&product=DC14-ALLFLOORS_US
Once you've removed any threads, hair and other obstructions from around the brushbar and cleaner head, you should find this resolves the issue. However, if you've tried this and are still concerned, please get in touch with us directly so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 23, 2011 | Dyson DC14 All floors Bagless Upright...
While on the carpet setting- when the arm is released- there is a loud noise...doesn't matter if it is on bare floor or carpets-- if on the bare floor setting there is no noise on floor or...
I'm sorry to hear you're having difficulties with your DC14 Animal. The cleaner's brush control system is designed to make a ratcheting sound to alert you if the brushbar is jammed. Although you've already cleaned the brushbar, it's a good idea to follow the steps shown in our online support guide to make sure you haven't missed any obstructions in the cleaner head:
http://www.dyson.com/support/help.asp?article=650&product=DC14-ANIMAL_US
This should allow you to resolve your issue without further assistance. However, if you've checked the brushbar and cleaner head are clear of threads, hair, or other obstructions, but the cleaner still seems to be making the ratcheting noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Sep 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Nov 04, 2009 | Dyson DC14 All floors Bagless Upright...
Marci
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Apr 12, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 all floors.
sept 30,08 bought dc14 all flloor. After 3 to 4 uses it started making lots of noise when on carpet setting. I examined the roller brush and it was cracked at one end. I returned it Oct 13 ,08 and got another dc 14 all floor. Now this one after 2 uses has the same problem only a larger crack in the brush and a small piece of the brush broke off. Very dissapointed.
Jan 08, 2008 | Dyson DC14 All floors Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
55 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
