Question about Hitachi 43UWX10B 43" Rear Projection Television
My hitachi digital hdtv has always had cable hooked to it,and now i have no cable and i cant get the digital chanels to work with the antenna
I went through the motion of reseting my hitachi hdtv and all i get is snow on every chanel.what do i do now? can anyone help me the tv is a good one.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The set will need a digital box to receive digital channels as it does not have a digital tuner in it--it is a very good set.
Posted on Dec 22, 2012
SOURCE: HITACHI DIGITAL ULTRAVSION HDTV PROJECTION TV
The color looks out of alignment
Posted on Jul 06, 2008
SOURCE: HDTV channels not working for
I assume you are using a Comcast HD cable box ..... that's the only way you will be able to view HDTV. You do not need a Hitachi HDTV tuner.
Posted on Mar 16, 2009
SOURCE: is my hitachi 46f500 projection tv ready for switch to digital
http://www.shopping.com/xPF-Hitachi-46F500
HDTV-Ready - Requires separate receiver to view HDTV signals.
Posted on Jul 10, 2009
  • 67 Answers
SOURCE: I have a Hitachi 57F500 HDTV SRS TV and can not get any chanels
unplg tv 4 30 min plug bak in if does not reset u will have remove supply voltage to computer clock 2 do this u must go into back of tv and look on board until u find a whats looks like a watch battery remove it wait 6 minutes reinsert it this just reset the clok in the microprcesser dumped the ram this should fix ur problem everthimg should go back 2 factory seettings read manual
Posted on Jul 25, 2009
  • 5 Answers
SOURCE: hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Posted on Aug 29, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My cable company just went digital. I have a TIVO
you will have to hook the tivo to the cable box and reconfiger, you will have to hook up the ir eye from the tivo to the box so thay can talk. the newist tivo is realy cool it take a cable card and can record muilt chanels but your old one when configured with the cable box will only record one chanel at a time and you wont be able to watch another channel wile its recording
Apr 15, 2010 | Vizio L32 32 in. LCD HDTV
Cant program chanels
Make sure that you are not scanning in cable mode, to get the local channels you will probably have to scan antenna, this will be in tuner set-up
Feb 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Is my polaroid TLX-04244B Digital
I checked out the manual for a similar model tv from polaroid...there's only one input for the coax cable from your antenna, so if the antenna's cable is connected to this input, this couldn't be the problem. What I do have trouble with on my own tv is that my indoor antenna location can make huge differences in recognizing all available digital signals. I could even have the antenna facing a different direction, and get different results. There are a few sites you can google for to find your distance from the broadcast towers, too. This might help to determine if you need a stronger antenna. It's a painfully long procedure to try different angles and positions for your antenna each time you run a channel scan, but this might be the only thing that would prevent you from picking up the digitals. I try the highest spot possible, and the one closest to the outdoors. Good luck, I hope you can pick them up soon! (Any antenna works...the industry tries to pass off "digital/hdtv specific antennas" to make a buck. I've used a cheapy rabbit-ears antenna and was able to bring in digital channels, as long as your tv or converter box is converting the signal.)
Jun 13, 2009 | Polaroid TTM-2401 TV
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Hitachi projection tv digital channel problem
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
