Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
My 3300mfp phaser is stuck on LSU motor error detecting
My fax/copy machine is saying "LSU motor error" "Cycle power" memory stored by nothing coming or going.
3 Suggested Answers
SOURCE: Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
  • 141 Answers
SOURCE: LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Posted on Aug 04, 2009
How can i fix this message LSU motor error cycle power
That error is caused by a defective laser unit and would need to be replaced. The part number is 122N00276 and available below:
http://www.iteminconline.com/122n00276_122n00276-122n00297-xerox-3600-laser-scanner-unit-lsu.htm
Mar 08, 2016 | Xerox Phaser 3600DN Laser Printer
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Scanner locked on Xerox phaser 3300MFP
There is a green switch on the top of area where paper comes out. That locks the scanner
May 12, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
HI I M JIGNESh patel i was purchase xerox pe in my printer error is lsu how can i solve it pls send me reply
I'm not sure what the problem is or what machine you are using but follow the link below and enter the name of your machine and then the error message and it should help!
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR
Dec 06, 2008 | Xerox Phaser 8500/DN Printer
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
490 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
