Question about Home
Sloan flushometer water leaking from outlet coupling
2 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: Toilet keeps running (Sloan FLushometer)
There is something fowling the shut of diaphragm you will need to disassemble and clean or rebuild with new parts.
this may help http://www.sloanvalve.com/Customer_Care/Technical_Downloads.aspx
Posted on Feb 13, 2011
I have a manual flushometer by sloan. It is a royal type, and when the unit is flushed water is leaking from the spud coupling where it connects to the porcelain bowl. I suspected the spud coupling was...
if a leak can't be repaired by tightening, you can try taking it apart fully and seeing it anything is twisted or perished. Best way though for trouble free use and peace of mind is a new coupling.
Jul 25, 2017 | Home
It is leaking around where the pipe inserts into the toilet
try a new o ring inside the the tighten nut which is attached to the water pipe
Dec 17, 2012 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Feb 13, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Flushometer will not stop flushing
The diapharm inside is got trash not allowing it to seat and shut off water.
Oct 26, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
My flushometer kicks in, spays refill water into the tube, for 2-4secs at periodic intervals with out any one touching the lever
The rubber diaphram in the top of the valve could be leaking or wearing out.You could try flipping it over sometimes that helps prolong its life.You could also turn the volume set screw counter clockwise to increase volume which tends to not let the vacume break as easily.Or you can try tightening the flush handle nut if it has gotten sloppy.My guess you will find debris in the large diaphram on top
Jun 22, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Not enough water ,need flush it 3 time in regal flusometer
the right side where water comes to it through wall there is a cap that can be taken off it covers the shut off valve that takes a flat head screw diver to shut off or open up all the wall. check and make sue it is all the way open.
If it is shut it off and the cap on top where the flush handle is remove it once water is turned off and check it out. the kits to rebuild one it should be a 37-a or 36-a to replace this part if that is it.
These are a couple of thing's to check
Jan 21, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Urinal will flush, but will not stop.
You will need a sloan rebuild kit. They are inexpensive, and fairly easy to install. Check Sloan's website, or a plumbing supply house for the rebuild kit. You do not have to shut water off to the entire building to do this work. You will notice a chrome cover on the front portion of the line coming out from the wall. Remove this cover, and you will find a flat head screw. Turn the screw clockwise, and this will shut the flow of water off that is going to the area you will need to work on. The rebuild kit will come with instructions on the install. Again, it is relatively easy to replace. Just make sure you shut the water off, or BIG SURPRISES in your future.
Nov 20, 2009 | Sloan 180-1 Exposed Urinal Flushometer -...
Home Logo
361 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
