Question about HP officejet 4200 series
My printer is stuck. Won't work. It keeps indicating fax mode. Strange thing, I have never actually hooked the fax up. how do I get it back to printing
Will not print anything from my computer or usb. not sure how to get it back to printing.
  • 639 Answers
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.If not then follow the following steps.
Please be informed that any Printer Driver software depends upon the hardware make and Operating System. You need to know all these information's to do get going.
Please find the Driver software's of your printer inside the installation disk provided with the Printer at the time of purchase. As you have not mentioned your Printer make I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the Printer.
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Printer Model number and the OS that you are using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
If you feel that my answers have helped you getting solution to your problems then please give a vote for best answer.
Thanks.
Posted on Nov 29, 2012
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
The fax dosn't work,what should I do? I don't have ring tone, and can't receve.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
May 14, 2012 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Xerox phaser 3635mfp Work printer, shut down one Friday, next Monday booted it up and a promt for a 'passcode' came up. We have never seen this before and bought the printer new. Is there a way...
i am assuming that someone accidently pressed the access/login button or the machine thinks they did (button stuck,whatever). the passcode is 1111 and assumes you want to enter the tools mode. Becareful if you go there as you cannot kill your printing and do various other things. just enter the code and then push the button mention above and logout.
Jul 26, 2011 | Xerox Phaser 3635MFP/X Multifunction...
I'm trying to send a fax on my Canon Pixma MX340 . It rings when I dial the number, but just keeps coming back and telling me the line is busy. That shouldn't be happening at this hour. Is there...
Thank you for using fixya.........
The receiver is not receiving your fax, so the problem is coming.......
first you have to inform the receiver to receive the fax........
then try again...........
thank you......
Jul 23, 2011 | Canon PIXMA MX340 Wireless Office...
I keep getting a 'Phone off the hook' message. Phone is not off the hook
Disconnect the power cord from back of the printer ( while printer is power on )
While holding the # and 6 key connect the cord back
( This step will erase all the fax logs and settings you have set on the printer )
Also
Press the Setup button and Scroll to FAX SETTINGS ( or ADVANCED FAX SETTINGS )
Check for ECM ( Error correction mode ) - Press OK
Turn it OFF
Finally if the issue is still not resolved,
Disconnect the Phone cord from Printer port and re-connect
Check for any other loose connections ( of phone socket ) within the house. ( disconnect and reconnect )
The Error message should go off
Oct 12, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Fax doesnt work
Go to control panel and open the printer. For faxing, make sure you have selected "Series FAX" and not the actual Printer.
This might be the problem
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Not receiving faxes
R18 means that your memory is full. Very strange. Go into the user box, file document, system user box, memory rx to delete all of the old faxes. This worked for me.
Aug 07, 2008 | Konica Minolta bizhub C250 All-In-One...
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
